Tinted windows interfering with XM and Traffic?
I brought my car in for 4 items - the three TSB's (XM & Real time traffic, PCM and OnStar) and my navigation seems to be 50-100 feet off.
The dealer told me that having tinted windows is causing XM channels to have a delayed refresh, causing the Real Time Traffic to stop working and is interfering with the GPS causing the Navi to be 50-100 feet off.
I have the silver tint (they say titanium in it) made by Johnson.
Anyone ever hear of this?
ASP is correct - metallic tint may cause problems with the navi. It CANNOT cause problems with the XM refresh delay or the real time traffic as the XM antenna is mounted in the shark fin on the roof. The navi gps rcvr is under the rear deck inside the car.
Sometime last year, right after I got my RL, I read in some car mag about the locations of the antennas for the various RL electronic systems. This is what I recall:
OnStar = Rooftop shark fin antenna
XM = Inside the brake light case, under the back window
FM = Wired inside back window
Navi GPS = (I can't recall where it's located)
If I remember this info correctly, then, it would explain why XM reception might be affected by window tint, since it is located inside the brake light case under the back window.
Found article re. XM antenna location!
I was right about the location of the XM antenna: It's inside the cover of the brake lamp mount under the back window.
The article is from a November 2004 Boston Globe issue. Here's the link:
http://www.boston.com/cars/articles/...lectronic_era/
or...
http://www.tinyurl.com/9cc76
In essence, it says:
"The fin on the new Acura RL sedan is strictly for OnStar. The carmaker conceals the XM satellite radio antenna within the cover for the center high-mount stop lamp."
Again, this would explain why improper tiniting would interfere with XM reception.
or...
He is correct, I just checked the service manual and the XM antenna is in the brake light. If the tints were causing trouble with the XM, wouldnt it cause problems with audio as well as a delay? it would make more sense that all functions have problems, NOT jsut the delay like the rest of us have.
Wow - Great info! Thanks!
I visited the dealer today again and as it turns out, they were just "grabbing at straws" because my VIN # wasn't associated with TSB 05-022. However, when the traffic went completely out, as indicitive of the AcuraLink defect, the service manager agreed to replace the module.
Great posts though.
PRNole47 - Thanks for the links - very helpful!
VP911 - where did you get a service manual? All I received, regarding service, was the log book.
Great posts though.
Perhaps the "polling" frequency was the problem...
From what I've been able to figure out, the AcuraLink CPU polls for data or information from XM on a specified time basis, i.e., it sends an "inquiry" or message to XM every few seconds asking for "info" on what is being broadcast so it can portray that info on the display screen. If there is no change in the data stream sent back by XM, then the display info remains the same until the next polling sequence takes place. If the next polling sequence results in new data being sent back by XM, i.e., a change in what is being broadcast, then new data is shown on the display screen (new artist, title, etc.).
What probably is happening is that the tint only interferes with the round-trip message data transmission produced by the polling sequence; however, the tint would not interfere with the audio since it is sufficiently translucent to allow the audio data stream to reach the unit. It's probably being sent on a different frequency.
Come to think of it, this is probably what caused the problem with the original XM display screen refresh delay: The AcuraLink update done in April changed the polling sequence timing so that the unit's CPU did not poll frequently enough to receive up-to-date data streams from XM.
Then again, I could be wrong....
![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Originally Posted by PRNole47
Perhaps not.
Then again, I could be wrong....![Yum](https://acurazine.com/forums/images/smilies/yum.gif)
Originally Posted by spacklebucket
*** SNIP *** ...However, I would think it is highly unlikely for tint to be causing the exact same problem that many of us have - and which has prompted a TSB to replace hardware. It is more likely in my opinion that the dealer is using the tint as ANY excuse to refuse warranty work because he can get away with it.
It may well be that the tinting issue is an *added* confounding factor that causes its own problems even for those RL owners that had the defective post-update units replaced under TSB 05-022. Sort of like excessive wax build-up on the windscreen from drive-thru car washes that *might* cause the sensor that controls those self-adjusting variable speed wipers to respond, given the amount of rain on the glass and speed of the vehicle.
If that is the case, I hope Acura and their dealers can rectify this additional problem, even if it's a matter of replacing the tint at their cost -- or complete tint removal, since I doubt they're going to be as accomodating in this case as they were when the April update ruined all the XM units.
Then again, Acura might say you got the incorrect tint and it's up to you to change it if you want the XM screen to work right.
