tilt and telescoping steering wheel issues
Chapter Leader (Chicago)
OK i have tried looking and searching. i am tired and i am hoping you can help me out...
i had an issue with my car... so i disconnected my battery... When i reconnected my battery.... the steering wheel won't adjust...
i hope you can help...
steps that i have done
1. Checked fuses
2. remove fuse and but back
3. Remove negative again battery..
i have a feeling its something so small but i can't figure it out... so any tips is highly appreciated thanks.
1. Checked fuses
1. Checked fuses
1. Checked fuses
Edit - from the owner's manual: "If your vehicle's battery is disconnected or the power tilt steering wheel fuse is removed, you need to reset the telescopic steering wheel system. Push the ignition switch for more than 1 second and release it, or insert the built-in key into the ignition switch, and remove it. The steering wheel automatically move fully in to let you know the system is reset."
Are you saying it won't adjust using the button or won't adjust automatically when you start the engine?
If the latter, you have to reset your Driver memory setting after disconnecting the battery.
ok i did that too... i put the key in the ignition and nothing... i also pushed in the key and that didn't work... so
please confirm. You open the car door. Move the black knob facing on the side of the column facing the door in all 4 directions and the steering does not move in any of those 4 directions?
If that is correct and it does not move - please look at page 103 in your owner's manual for instructions how to turn it back on. (page 103 is from the online PDF manual and it looks like that is the actual page number in the paper manual).
well battery was taken off b/c it wouldn't start so i took the batt to charge it at Autozone. But my surprise the battery was good. and the issue was that i had a 10w amp blown... so replaced it and bam it turned right on...
Update!!!
yes i did check the fuse. took the fuse out put it back in... did everything lol...
all in all the Motor was fried... so called my warranty and took it to the dealer and they will be replacing the unit tomorrow...
in the mean time i am pimping a MDX 2011... loving it...
