is there a tsb on the torque converter?
Old 08-26-2009, 03:27 PM
poppintec's Avatar
whats up, so i am curious to know whether there is a tsb on the torque converter because at about 2200 rpm and maybe 1400-1600rpm i feel like a very slight vibration off the pedal that i don't believe should be there..... it is not a serious issue, but I want to approach before it becomes one, i have warranty for a few more thousand miles wondering if anyone else has experienced this...
Old 08-26-2009, 10:52 PM
Rob144's Avatar
Do you get the same effect in neutral at that rpm?
Some engines simply have a "rough spot" or two in the rpm range, usually down low. My '95 Legend had a "rough spot" in the lower rpm range (about 1400-1600) which was just a characteristic of the engine. A little higher up, there was a gentler rough spot.
knight rider
03-04-2016 08:59 AM
thegipper
09-28-2015 01:01 PM
hpfiend
09-27-2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
09-25-2015 10:34 AM
JOE COOL
2G RDX Problems & Fixes
09-24-2015 07:15 AM
Quick Reply: is there a tsb on the torque converter?
