Switchable interior fuse link for V1 install?
Old Aug 14, 2007 | 06:53 PM
gasportrider's Avatar
6th Gear
I have completed a Valentine 1 installation on the RL using the suggestions posted on the TL site as follows:
https://acurazine.com/forums/showthr...ight=Valentine
The TL posting makes reference to the power windows fuse being switchable with the Main Power Switch. I tried both the left rear passenger window fuse # 24 and the driver window fuse # 27 and find that neither are switchable from the Power Window Main Switch located on the left arm rest.
So, at this point I have to remember to manually turn off the Valentine using its on/off rotary dial rather than relying upon ignition switching or the power window main switch.
Does anyone have a fuse recommendation for a direct wire of the Valentine supplied remote power adapter that will give me ignition switching?
BTW, using a plastic spatula and a cake icing spreader, I did not have to remove any part of the interior trim other than the footwell trim that covers the fuse box.
Old Aug 14, 2007 | 09:22 PM
Mike_TX's Avatar
AcurAdmirer
I'm not sure what all you're trying to do, but I can tell you what I did to connect my
Escort 8500.
I used the ACC fuse at position 32 on th driver's side fuseblock. It switches with the ignition. I used an Add-A-Fuse, which you can get at most auto parts stores. It turns one fuse outlet into two, with each circuit separately fused, and it is a simple plug-n-play deal. I grounded to a screw in the vicinity (can't tell you which one right at the moment, but check out a few for ground until one works).
Easy, quick and it works like a champ.
Old Aug 15, 2007 | 01:44 PM
Touge's Avatar
+1 on what Mike said. I did it the same way.
Old Aug 15, 2007 | 02:16 PM
cullal's Avatar
+2 on Mike's post.. same process and it works fine..
Old Aug 15, 2007 | 04:08 PM
UW RL's Avatar
The Doctor
Mike's right, that's how I hardwired my Escort 8500
Old Aug 17, 2007 | 05:29 PM
6th Gear
Thanks for the suggestions
Thanks for these posts. I'm just back from a trip and I'll try the accessory connection this weekend.
oo7spy
Jun 19, 2023 12:48 AM
Feb 25, 2020 09:57 AM
james357
Feb 13, 2016 02:37 PM
asahrts
Sep 4, 2015 05:55 PM
nuldabz
Sep 3, 2015 05:49 PM
