stupid question about bulb sizing
what is the bulb size for that.....?
I'm thinking about converting the running light to white LED or HID. A link to where I can buy the bulb or kit would be greatly appreciated. Thanks http://img18.imageshack.us/img18/6428/52306891.jpg |
Those are 9005's and you can also use Halogen Infrared Reflector bulbs in the 9011 size ( I did ).
Search is your friend, but the H-11 HIR bulbs are really good. You just need to cut a tab.
https://acurazine.com/forums/2g-rl-2005-2012-76/bulbs-sizes-rl-710860/ https://acurazine.com/forums/2g-rl-2005-2012-76/drl-replacement-718423/ http://hirheadlights.com/ |
so would this led bulb replace the 9005 bulb running and would it high beam as well?
HB3-WHP9 DRL LED bulb http://www.superbrightleds.com/cgi-b...gi?product=CAR |
Originally Posted by Silver_RL
(Post 10746051)
This would not work for anything except DRL. The lumen output is probably about a magnitude off of what a real halogen or HIR puts out for high beams. Since you would have no high beams, you may be considered illegal according to state and federal motor vehicle codes, although I know that never stopped anyone, unless you have annual inspections like we do here in VA. Personally, I like having the high beams.
I dropped HIDs into mine. You lose DRL, you get bad @$$ HID for get out of the way action or night driving.
Ebay kits go for $50 shipped, I went with 10k |
Originally Posted by Ballinger
(Post 10740840)
thanks for all the input guys. I think I will go with either piaa bulbs to make it keep both drl and high beam or maybe with a HID kit but I really want to keep my drl. :rolleyes:
I got the PIAA Super GT-X bulbs with purple tints, let me know if you want them. I decided to go w/ HIDs ultimately.
037, I'm itching to get rid of my DRL...so you put HID into the high beam, do you get the "CHECK DRL" message on your gauge cluster?
Chris |
I do when I have my lights in the off position.
I just drive with my lights on all the time, so that is rarely an issue. On another note, you will have to go with a higher fuse, standard is 10 and I blew 2 of those already. My mechanic said a 20 should be fine since the flow is not constantly huge, but that sometimes it spikes and knocks out the weaker 10. |
