Strut and Shock replacement
Old Apr 11, 2014 | 08:51 AM
map0824's Avatar
Unhappy Strut and Shock replacement
I have an 07 RL that originally had the PAX tire set. When they wore out I replaced them with after market wheels and rims. So the original PAX were 17" and the replacement set I purchased were 18". The car has 73,000 miles on it. I just replaced the original set of 18" tires and after only 4,000 miles I am seeing feathering. The Firestone salesman said that is because of my Struts and Shocks being worn and needing replacement. I would think that it is to soon. Does anyone feel I need to replace my shocks and struts or is this more about the different size tires on the car or any other explanation.
Old Apr 11, 2014 | 09:00 AM
by looking at the car and your description, there is no way of telling if your shocks are bad.
the firestone sales man, was being a salesman.
an alignment is a great tool to figure out if you have worn suspension pieces or if its just simply out of alignment.
I would advise getting an alignment first, to see where you are at.
Old Apr 11, 2014 | 09:20 AM
map0824's Avatar
I did an alignment when I purchased the tires. That was only 4K miles ago. I was not told that the car could not be aligned because of any reason.
Old Apr 11, 2014 | 09:24 AM
post up the alignment sheet.
it's a tool/instrument for us to see whats going on.
Old Apr 11, 2014 | 10:32 AM
oo7spy's Avatar
https://acurazine.com/forums/showthr...ighlight=shock
I only went back to 2012. I got tired of looking through so many threads about the same topic.
Old Apr 11, 2014 | 10:38 AM
great answer:
Originally Posted by oo7spy
The life will depend heavily on the roads driven and the style of driving. How often are you going up and down? How often are the struts being fully extended or slammed down? Also, some RLs here have experienced blown struts after the car was put on a lift, and the age of the struts under stress will play a role too.
I didn't get a chance to change mine b/c I killed the car too early. However, on Legend #1, I had a blown rear strut at ~150k miles and 13 years old. Honestly though, the struts should have been changed before I bought it at 114k miles and 8 years old. The car rode well, but I bottomed out often. I attributed that to the height of the car until I changed all 4 struts and never bottomed out again.
Struts are a wear and tear item that are sort of hard to judge. The biggest issue is that the decrease in performance is so slight, that you don't notice the difference. As they wear out over 100k miles and 7 years, you get used to how they change. It isn't until they are changed that you can tell the night and day difference. I would suggest changing the struts on a heavy luxury cruiser like the RL every 100-120k miles. The car is designed for comfort, and it is a heavy pig.
Old Apr 11, 2014 | 11:55 AM
BDoggPrelude's Avatar
Who did the original alignment? Firestone? Get a second opinion on the alignment/shocks.
Old Apr 11, 2014 | 12:30 PM
I would love to check out the first alignment sheet first.
to see if everything is spot on.
if something isnt spot on, i'll be able to tell real quick.
then we can look at things that affect the alignment.
Old Apr 12, 2014 | 03:56 AM
It might help if you posted pictures of the irregular wear too.
Old Apr 12, 2014 | 08:04 AM
octoher12's Avatar
What does he mean when he bottoms out?
Old Apr 12, 2014 | 11:59 AM
oo7spy's Avatar
That was in Legend #1. The car was designed much lower to the ground than the RL, and the sagging struts likely didn't help anything. There was only 4-5 inches of clearance between the ground and the bottom of the front bumper. When I say bottoming out, I mean the bottom of the car touching the ground. Usually it was the front bumper, but occasionally, it would include the splash shield and oil pan. This could happen on slight dips at speed, larger dips going slow (like ends of driveways), or speed bumps. Anything that caused a sudden weight transfer vertically would cause something to hit. After I changed the struts, 90% of what used to cause contact didn't any more.
Old Apr 17, 2014 | 09:32 AM
map0824's Avatar
Are the Struts and Shocks the same on all 2007 RL's or are they different for models that had the PAX option?
Old Apr 17, 2014 | 10:33 AM
Different for the PAX. All are interchangeable but I would definitely recommend replacing in pairs mixing.
Old Jun 12, 2014 | 04:24 PM
tlmaster1's Avatar
just get the A-spec wheels and suspension and call it a day. your car will feel so much better, ride and cornering.
Old Jun 15, 2014 | 01:43 PM
Mr.Tea's Avatar
I am in the same position with my struts…took the car to SEARS to have it realigned for the second time in the same months. I am just now seeing that my shocks are gone…rough ride, bumpy over every road.
I am going back with the (OEM) struts do i have to replace all (4) at once? and if so is the A-SPEC better?
Old Jun 17, 2014 | 04:19 PM
tlmaster1's Avatar
way better, go with a-spec
Old Jun 19, 2014 | 03:56 PM
stevieray's Avatar
2007 LSM KB1 Tech w/CMBS
Good luck with finding an A-Spec suspension kit. Might as well be looking for a Yeti. I have wondered if the MMC suspension which is supposedly very similar to the A-Spec would fit on the '05-'08 KB1. Anybody?
oyayjoe
Jan 1, 2019 10:17 PM
marcelft
Jul 10, 2018 06:17 PM
acurajj
Feb 14, 2016 02:28 PM
Heyzuez20
Oct 14, 2015 07:18 AM
Nicho863
Sep 3, 2015 09:16 PM
