Spark Plugs
Old Aug 3, 2009 | 11:25 AM
Blazing GT's Avatar
Spark Plugs
I am aware that the RL requires 6 spark plugs. My question is:
are these spark plugs good?
by NGK
http://www2.partstrain.com/store/?N=...7c&id=t2ympdz6
Old Aug 3, 2009 | 12:36 PM
Rhlieu's Avatar
The NGK/Denso are OEM stock for most Honda/Acura.
When i had my 105k tuneup on my TL, i upgrade to the NGK Iridium plugs (suppose to be higher quality/better proformance)
Old Aug 3, 2009 | 12:39 PM
CGP CL9's Avatar
Low is a Lifestyle.
iridium iridium iridium iridium iridium iridium
bosch or ngk!
Old Aug 3, 2009 | 07:15 PM
rlerman's Avatar
I haven't priced out spark plugs for the RL yet, largely because I still have 45k to go before it needs it, but those plugs you link to look awfully expensive. Bosch plugs are fine to use, $2 each for platinum tipped.
http://www.autopartswarehouse.com/se...=10&Ns=price|0
Old Aug 4, 2009 | 07:30 AM
OLD_HATCH's Avatar
platinum is what the RL comes with I think. Iridium is supposed to be a step up from platinum with better performance fuel economy.
I know that the NGK Iridium IX are about 7 bucks at almost any auto parts store and are supposed to last 50,000 miles while the ngk laser iridiums are supposed to last 100,000.
I myself am about to try the iridiums over the platinum to see if there is any noticeble difference.
Old Aug 4, 2009 | 10:47 AM
Blazing GT's Avatar
well i only have 45k miles on the car....
but it wouldnt hurt to change them now
how do you do a tb service?
should i just open it up and clean it?
Old Aug 4, 2009 | 04:49 PM
RL Chi-town's Avatar
Chapter Leader (Chicago)
only 45k...
damn mine has 48k 06 RL
Old Aug 4, 2009 | 06:31 PM
rlerman's Avatar
The plugs that came with the car last 100k miles, why raise the cost of ownership.
Old Aug 4, 2009 | 11:00 PM
Rhlieu's Avatar
+1
Changing new spark plugs won’t yield sufficient horsepower gain or enhanced mpg (unless they are misfiring or totally toasted)
Old Aug 5, 2009 | 11:49 AM
rtr's Avatar
rtr
RL owner
denso ik20 irideum is what i run! the best for the best
Old Aug 5, 2009 | 12:12 PM
23109VC's Avatar
i used to have a volvo S60R making close to 350 crank hp due to ECU/dp/exhaust. I changed out my stock plugs, that had about 45k miles on them, and put in denso iridium plugs. I didn't notice anything... don't waste your money. unless your plugs are BAD - you don't need to change them, and honestly, I don't think using the OEM vs these $$ plugs will yield any power on your RL. on my S60R, which was pretty darn fast - it was about as fast as a stock E46 M3 (track proven!) - it didn't do squat - i chalked it up as a waste of money at the time... YMMV..
Old Aug 5, 2009 | 01:12 PM
Rhlieu's Avatar
I concur that changing the spark plugs before the 105k recommendation is not needed. However, upgrading from oem to iridium plugs would be a worthwhile investment(+$20 vs oem NGK) since it won't get replace again for another 6/7 years or another 105k.
Old Aug 5, 2009 | 01:38 PM
23109VC's Avatar
i can't speak to how long they last...they could last longer than OEM.
my only point is that for an RL owner - changing plugs from OEM to iridium isn't going to yield any real world gains that you would notice in day in day out driving...
i had a fairly high perofrmance sports sedan that was modified, and changing plugs didn't do anything that my butt dyno could detect....
if I was going to change the plugs b/c I was at the 100k mile mark, surek,k why not put in the best plug available.. but if you have 45k on your car and are looking for a "performance" upgrade, I'd pass on the plug swap...
Old Aug 9, 2009 | 02:15 AM
rtr's Avatar
rtr
RL owner
you guys need to do some research the RL comes stock with iridium plugs! They last 100000 kilometers under normal driving as they get old they will slowly affect fuel economy and throttle response. Im sure if you pull them out and see them all rust color at the bottom of the porcelin and gap are diffrent that happens over time to. It took me 30mins to change the plugs and i bought them off EBAY. Denso IK20
Old Aug 10, 2009 | 07:44 PM
470hpGS400's Avatar
Agreed, just because a plug may last 100k does not mean it is performing the same at 100k as it would at 5k.
Plugs are easy to change on the RL, just avoid those Splitfires and Pulstar plugs.
Old Aug 10, 2009 | 11:27 PM
mcdillon27's Avatar
Agreed... the '05 + RL comes stock with Iridium plugs... can't remember if my 04 RL came with iridium or platinum.. either way I replaced them with the Bosch iridium at 100k miles. For my 05, I will probably replace with the stock NGK iridium plugs.. and yes, this is an easy task to do. Save the $ and do it yourself.
Old Aug 11, 2009 | 07:11 AM
FredS's Avatar
I have a 07 RL with 103,000 miles and was looking at changing the plugs. The dealer wanted big bucks to do this. Has anyone changed them on a 05-08? Was it easy? Looking under the hood especially the back three, it looks like a bear!!
Old Aug 11, 2009 | 10:49 AM
470hpGS400's Avatar
Back three are easy to get to. Just need a few extensions. Disconnect the coil pack. Remove the 10mm nut holding it down-don't drop it.
Remove spark plug, inspect, reverse the order. Simple enough.
Old Jul 29, 2016 | 11:01 PM
billzblaze's Avatar
I know this is an old thread but i had to say i just found our plugs on ebay for $36.00 had to buy em since timing service is coming up..9807B 5617W Spark Plug Laser Iridium for Acura Honda NGK 6994 IZFR6K11 1 PC | eBay
Old Jul 31, 2016 | 11:03 PM
TakeiTeg's Avatar
I too changed mine at about 90,000miles. car is significantly smoother, i used NGK IZFR6k11 as well, Laser iridium.
Mike734
Dec 10, 2021 01:25 PM
acuratl26
Apr 23, 2020 07:30 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
