ShAwd light on
Old Mar 17, 2023 | 01:53 PM
Heclaboy82's Avatar
6th Gear
ShAwd light on
My Shawd light is on and the navigation screen has a all wheel drive dtc:81 error code on it. The car has a bad rear left wheel bearing that I'm waiting to get fixed. Can a bad wheel bearing cause shawd issues?
Old Mar 17, 2023 | 07:56 PM
altair47's Avatar
Yes
Old Mar 22, 2023 | 08:03 AM
Blues Legend's Avatar
Probably the ABS sensor is getting a bad reading, or has even been damaged - depending on the amount of play in the bearing.
Computer doesn't like the signal.
I'd check the battery connections and fully-charge it, since it's easy and you never quite know with RLegendos.
Old Jun 17, 2023 | 10:57 AM
deadhead21's Avatar
I would check the fuses to be safe. I was doing some tinkering and noticed unplugging the VSA fuse made my AWD light come on
Old Jun 29, 2023 | 05:57 PM
Heclaboy82's Avatar
6th Gear
Checked fuse all was good. Gotta get that bearing fixed, to see if it fixes that error. I checked service manual and it state that a 81 code on HDS has to do with left coil( could be sensor or magnetic coil)
Hopefully when bearing gets fixed it can clear that up.
Vividsi
1G RDX Problems & Fixes
36
Nov 11, 2019 11:16 AM
bentleymp21
May 23, 2015 08:12 PM
pepperish
Feb 25, 2013 07:27 PM
wcoy
Dec 11, 2008 06:16 PM
paul_philly
Oct 31, 2005 06:21 PM
