My Shawd light is on and the navigation screen has a all wheel drive dtc:81 error code on it. The car has a bad rear left wheel bearing that I'm waiting to get fixed. Can a bad wheel bearing cause shawd issues?
I would check the fuses to be safe. I was doing some tinkering and noticed unplugging the VSA fuse made my AWD light come on
Checked fuse all was good. Gotta get that bearing fixed, to see if it fixes that error. I checked service manual and it state that a 81 code on HDS has to do with left coil( could be sensor or magnetic coil)
Hopefully when bearing gets fixed it can clear that up.
