SH-AWD Survey
#41
Originally Posted by RL06tech
Yep, same thing here. The correct reaction is to lay off the accelerator and let the system do its thing the problem is that it all happens very fast, however in my expirience the car hasn't completely gone out of control. SHAWD is great and does work wonders but it can't eliminate the physical laws of adhesion! ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
No, not at all...
This is my first car with VSA, and I liken the experience to learning how to drive with my first car with ABS.... when I was a kid, and things like ABS didn't come on cars, we were taught "threshold braking" -- pump the brakes and/or modulate pressure to keep the wheels from locking up, and don't steer with the brakes locked.
Along comes ABS, and I had to "un-learn" that behavior, and learn to mash the pedal as hard as possible and steer around an obstacle.
OK, so, now, 20 years later or so, I'm re-learning how to react to skids.
The VSA correction can be violent, and unexpected... and I think it's worth it to spend some time on an empty mall parking lot in the rain or snow, learning how to deal with it.
#42
Originally Posted by jftjr
No, not at all...
Note, were not banging VSA, which is the most important safety device since seatbelts, were discussing its actions when driving the car at racing speeds and maneuvers, which a different ball game altoghether. In my expirience Honda has if not the best, certainly one of the best stability control systems in the industry, it allows some play while maintaining you safe. However SHAWD makes the RL and other such equipped vehicles to behave differently when driven beyond their very high limits, were simply sharing our expiriences and thoughts in those situations.
#43
My experience with SH-AWD is that when accelerating through a turn, the "feel" I get from the system is that the steering wheel doesn't "fight" me. In other cars, when cornering at higher speeds, the car will want to try and go straight and you sort of "fight" the wheel to continue turning. In the RL, I know the SH-AWD is engaged because the car just turns with no effort.
What an incredible system.
#44
#45
Go Big Blue!
Update: I took someones advice and tried to see what would happen on a sharp curve without applying gas. They were right. If you can belive the display the sh-awd kicked in and applied power to the back outside wheel eventhough I wasn't powering through the curve. Still only got one bar but it definitely showed extra power to that wheel. Interesting.......
#46
#47
Go Big Blue!
SHAWD works at all speeds however it can only transfer the torque you give it!
By the way, it took the turn like it was on rails. I don't want to do that often with these expensive PAX tires but I was impressed.
#49
Go Big Blue!
Here's some text from an article I read describing SH-AWD. It appears SH-AWD does in fact kick in without the gas pedal being pressed -- as some stated. It will use acceleration to stabilize a car through a turn to compliment VSA
"The system is comparatively simple, according to Mr. Tokushima, using a transfer case at the front, and a rear differential and two clutches at the rear to distribute torque. It is "proactive," as well, meaning that SH-AWD anticipates vehicle behaviour in particular conditions, and continuously compensates (it's "always active" says Mr. Tokushima) by distributing torque between front and rear wheels, and from side-to-side at the rear.
Likewise, if you're accelerating through a corner, and you abruptly take your foot off the gas, the SH-AWD system will work to stabilize the vehicle.
In case you're wondering, this is different than electronic stability control, where the throttle and brakes are selectively applied when sensors detect wheel slip. In many cases, in fact, braking responses from some stability control systems can come on too suddenly for many drivers, almost stopping a vehicle. Often, it's acceleration that's required to enhance stability, and here is where SH-AWD uniquely (at this point in time) has an advantage. "
#50
That's what I would have intuitively thought. However, the display showed power going to that back outside wheel (one bar) while all other wheels had no bars. This was while I was making a hard right 90d turn at an intersection with my foot off the gas doing around 30mph. Maybe the VSA is taking over?
#52
mu understanding is that the unbalanced torque on the rear wheels will happen in either acceleration or deacceleration. It is most evident in very hard acceleration through a corner. It is a bit un-nerviing, but you actually get more control if you get on the throttle through a corner. In this case, you can definitely feel the effect without having to try and look at the MID. I have felt it in both wet and dry conditions. As someone else mentioned, the wet condition will often bring VSA into play which does create some interesting effects, but I never felt out of control.
#53
Go Big Blue!
1) The sh-awd kicks in when the engine is applying thrust to the vehicle. The easiest way I've found to see the effect is to take a right 90d turn and jump on it as you enter the turn. You get 5 bars on the outside wheel every time.
2) the sh-awd also works when the engine is idle in a turn. From what I've read the sh-awd acts somewhat as a pre-vsa system to try and ANTICIPATE stability problems and keep the car on track if it senses extreme yaw in the vehicle and responds. it does this by gently overdriving the outside wheels and kicks in BEFORE any problems occur.
3) the vsa system works WITH the sh-awd when the computer determines the vehicle is in an active drift. It then starts applying brake power to reposition the vehicle in the direction the driver is steering while sh-awd applies power. How it coordinates all this is impressive.
This is only my own personal conclusions from what I've seen and heard. I'm no expert on these systems. I admit I am talking out my ass on this a bit. Regardless, it's all very very impressive
#54
I agree. I was the one who started this thread because I was unsure mine was working. However, I now realize I was misunderstanding how it worked. I've "tested" it out over the last few days with the help of comments from here and now see that it works just fine on my RL. Very cool stuff. here's what I learned from my own experiences and everyone elses input
This is only my own personal conclusions from what I've seen and heard. I'm no expert on these systems. I admit I am talking out my ass on this a bit. Regardless, it's all very very impressive![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
#55
I didn't want to start a separate post on this becuase my problem is some what related. When I am stopped up a hill even though I am in drive, the car will roll down hill (backward). I have to have my foot on the brake or be hitting the gas or I'm rolling in reverse downhill. Is this normal?
My 99 Audi would lock in place. Its not a big deal but can be an annoyance when driving in hilly cities like SFO. Mainly I just want to know if I have a problem.
#56
joflewbyu2
08-18-2019 10:38 PM
