ROTORA Slotted and Combo Discs
Old Jun 5, 2007 | 05:23 PM
Excelerate's Avatar
Former Sponsor
I know that some of you RL owners will be coming up on replacing your discs so I wanted to let you know that ROTORA does have performance OE replacement discs available for your RL. Here is some info:
Developed with the same parameters as the Original Equipment (OE) specifications in both quality and finish, Rotora’s direct replacement brake discs are assured to meet and exceed all vehicle manufacturers’ specifications and tolerances under the worldwide ISO 9001 quality standards. CNC machined and balanced for optimum performance, Rotora’s brake discs feature special segmented slot, or drill & slot pattern which is applied to the disc’s front and back surfaces to ensure maximum heat and gas dissipation for greater stopping power and minimize warping and cracking caused by repeated, high stress, high temperature braking. With an “e-coat” (black) plating finish as an added protective layer to reduce corrosion and prolong disc life, Rotora’s brake disc quality guarantees top performance and longer durability.
Mill balanced to eliminate disc vibrations.
Uniform thickness and finish of braking surface to ensure improved pad to disc fitment.
Precise tolerance to ensure correct run-out.
Rotora's slotted and combo performance rotors are double disc ground and milled balance to ensure all OE specifications and provide maximum stopping power.
Slotted Disc: Segmented slot pattern for improved pad grip and pedal feel. Cleans away debris between pad and disc. Minimize warpage and brake fade.
Drilled & Slotted Disc: Segmented radius drill & slot pattern for improved pad grip and reduce noise. Cleans away debris between pad and disc. Ensures heat and gas dissipation.
Feel free to PM me with your vehicle info and what you're looking for (i.e. slotted or drilled and slotted discs, front and/or rear, SS brake lines) and what your zip code is and I can get you pricing.
Old Dec 6, 2007 | 08:07 PM
PWLegend2007's Avatar
how much for drilled and slotted rotors front and rear for 2007 RL?
Old Dec 6, 2007 | 10:58 PM
Jaysmith2000's Avatar
5Zigen Acura RL
NICE! These are on the LIST ....
Old Dec 6, 2007 | 11:03 PM
Roy Cya's Avatar
Me first!!!
Excelerate,
YGPM!
Thx,
Roy C.
Old Oct 29, 2008 | 12:04 PM
Ballinger's Avatar
Excelerate, do you offer a package price/deal on full kits, ie "Slotted & Drilled" for 4 wheels, with SS brake lines & Pads?
Old Oct 30, 2008 | 01:24 AM
470hpGS400's Avatar
Do the rears have a uniform pattern? The one's sold elsewhere have large gaps between the series of holes on the rears.
Old Oct 30, 2008 | 07:16 AM
Blazing GT's Avatar
a few more months a few more months
I hate the economy as of TODAY!
08KBP_VA
Oct 22, 2019 01:55 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
