RL died
RL died
So I was just driving my RL home and it was driving fine. Upon stopping at the traffic light near my home, all sorts of warning lights were coming on, such as charging system, sh-awd, power steering. I could smell something burning. When the light turned green, I could barely move, and it felt like the car was stuck in a higher gear. I finally made it home (just about a half mile) and parked. Turned off engine, and now car is totally dead. Battery is about 1 year old. When I opened the hood, I did smell a burning smell.
There is literally no power at all. Door handles do not work. I have to use the physical key in the slot to lock/unlock the door. Even the little green LED light for the "door" button does not work. Towed car to dealer. I'll find out on Monday what their diagnosis is. I am suspecting it is the alternator.
well, the first step would be to look at the charging system, the battery and then the alternator.
both items could smoke and provide a burning smell.
also, the way you worded "first time something broke in 14 years" sounds like you havent maintained it in 14 years. lol
but i know that isnt the case, as I know you maintain it.
Bearing can get stuck in Honda alternators.. I had a couple stuck alternatators due to the bearing failure.
From reading your post seems like u will make this repair very easy: throw away old RL and buy new one from dealer.
Haha, I very much doubt that will happen here. I keep cars a long time, until they become too expensive to repair. But if I did get rid of it, I'd be replacing it with something new, not used. I might consider a TLX with SH-AWD but only after the next FMC with the updated infotainment stack.
Keep the RL then... Better car...
I'd just keep fixing it like 4cruzin and clymerdude.
And if I needed another car, hunt down a clean one!
But, that's just me though...
Honestly if you pay someone to do the work.. older cars may not be that great. Japanese cars are great if you are a good mechanic and do work yourself. Germanistani cars can actually cost you more than brand new in 5-6 years of ownership. I know some who dumped 20k in used germanistani car repairs over 8 year ownership.
I keep expenses notes.. purchased 2009 Honda Odyssey for 4400 3 years ago. Spent 4000$ already (but it had Acura rl 2008 cylinder heads, pre cat delete. New tires. Timing belt, suspension, poly bushings, big brake calipers from Honda pilot, Acura RL wheels. And tons of others little things things add up. Engine mounts. New radiator etc etc. Plus shit load of time. Wheel bearings
Steering rack, transmission flushes, alternator
So things may not be as cheap . Those who spent 20k on BMW repairs for furious once they calculated everything.
Keep up with the maintenance and they're good!
I think even if you pay someone to do the work, it's still cheaper than buying a new car. My philosophy has always been to buy a good quality car (not necessarily "fancy") and keep it until it's not worth fixing. I'm middle aged and have only owned 4 cars in my life, 3 of which are still owned by me. It's a great way to not waste money, constantly buying new cars.
That said, after the alternator repair, it's driving great. My dealer always does an inspection each time I'm there for a service, and everything is "green" on their checklist. Of course, some things will still break without warning (like alternator) but even if you spend $1-2k per year on repairs, that's cheaper than spending $45-55k for a replacement, which is likely what I would do if I had to.
I'm glad your battery survived. I had an AGM battery in mine, that was wrecked when the alternator died. Had many of the same symptoms as you described. Lucky for me the battery was under warranty, and pep boys replaced it without question.
