RL 2006 (bolts torque and more)
Hello, Acurazine community!
recently my ODO reading 156k. I started to maintain my car as well as oil change, transmission and rear differential fluid. Later on, I replaced the engine fan because it was making string noise. I got all my scales from the internet such as watching DIY YouTube tutorial or being here to read.
I think I will have to change the timing belt, tensioner, and the water pump. But because this is will be my first time doing that, so let's say if I removed the crankshaft pulley using my power tool
1- Could I use the power tool again to put it back ? and how I know the torque for that crankshaft pulley?
2- I don't have any idea to know all the bolts torque that I have to put it back in the place. For example tensioner,the power steering I might need to remove it too, engine mount! what's else etc....
If you would like to add more knowledge to my subject please feel free!
Thank you, Acura Community!
[QUOTEtruonghthe;16125350]Funny that you mention the fan making noise because mine fan making noise too, is it the A/C fan that making noise?[/QUOTE]
True, I had to change both fans but it was a little bit expansive.The problem with my AC fan it was working and the plastic fan was unplugged. I tried to attach it but I end up screwing it more loooool. So that I just ordered a new one (No AC for 2 weeks hahaha). Next thing it was the engine fan, I started to hear a noise didn't know the source of it, later on, I discovered that was the engine fan and I replace it completely.
It does not help at all. I'm looking for someone able to answer the questions in a video or pictures should be perfect. I wish if Acura have timing chain instead.
