Remote Window Control
When I purchased the car, the dealer told me that the remote can control the windows. I've since found that only opening is controllable and closing can only be done from the car. This is a severe disappointment. When I told this to the dealer, they told me I was wrong and spent about 30 minutes trying to figure out why it didn't work... It seems that they simply never tried it.
Does anyone know how to close all of the vehicles windows remotely? After reviewing the acura website, it does not appear that the car has this function.
(WHICH STINKS!!!!) I can remotely open my windows... which is marginaly usefull, but when it is raining, remotely closing the windows is much more usefull...
Anyone?!
Anyone?!
Anyone?!
Anyone?!
That is correct, you cannot remotely close the windows. It is the same on the TSX and TL. If I am not mistaken this is a legal reason - so you can't be standing away while some kid has their hand in the window and gets stuck while closing it.
Somebody on the TL forum had figured out a way to bypass this and remotely close it. I don't know if it will work with the RL or not.
I got curious yesterday and put my hand in between the window as it closed. The moment the window felt resistance, it immediately opened right back up.
Seems like it should be easy enough... If you turn the key to the left, it closes everything... If I can ever figure out my remote start problem, I may have one of the extra keys on it's controller hit the input the turning the key to the left does.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Also, does the sunroof have the same feature where it retracts when it feels resistance? Some kid could be standing on the console looking out of the sunroof.....
Originally Posted by bkw
I dont think that this is the reason.
Black
on my Audi A4 and S4 I had to reprogram the ECU to allow for window closure. No idea why VW/Audi put radio and "personalization" functions there, but it was the only way to do it. Wonder if there is a similar hack for Acura/Honda...
https://acurazine.com/forums/showthr...03#post4836703
We've never done an install on an RL, but this module should allow you to put the windows up with the OEM remote. We've had positive results with the TSX and the TL.
We have put a few window modules on BMWs, but have found the BMW market to not be the best market when spicing wires is concerned. They all seem over worried about warranties!
FWIW, on the new Lexus ES350, I read that the remote can open/close driver's side or all windows.
On a side note, it would be nice if Acura had a similar on-line presentation as this from Lexus (for the ES350): <http://www.lexus-eshowroom.com/eshowmac/eshowroomnew/esdemo.asp>
Black
What tool did you use to gain access to the ECU's programming on your Audi, or was it done through the cars controls?
My dealer used the VAG 1551 (I believe) tool which is used for diagnostics/analysis (via OBD-II port in the car). Others have the notebook computer-based software which interfaces with the OBD-II port.
It's based on an aggregate number, so you pick and choose your options and then have the dealer update the overall value. Sounds a bit odd but it all works in the end.
Driver-selectable functions (minimal on TL, moreso on RL, and beyond comprehension on the BMW M5 or Mercedes-Benz S550) have limited the need for low-level programming, but things like window down and up are still restricted due to liability (catching ones fingers in the window).
SinCityTLX
10-07-2015 01:24 PM
xsilverhawkx
09-28-2015 06:51 PM
