Rearview Mirror Buzz
Old 01-30-2012, 02:00 AM
sleepinxlionhart's Avatar
Has anyone noticed that there is a buzzing sound coming from their rearview mirror? I noticed for mine, it only happens when the green light on the rearview mirror is on for the "auto dim" feature. When turned off, the buzzing goes away. I don't know, but it also seems to do with the uneveness of the road to some degree, but I can't say that the uneveness of the road plays a significant factor.
Old 01-30-2012, 07:25 AM
db22's Avatar
I have had the same issue. I think that it is just the assembly because when I squeeze it together the problem goes away for a while. I have not had any link to the green light except that when you press it then the pressure on the unit eliminates the small vibration. Yes an uneven road will "wake" mine up again but a small squeeze will fix it.
The other noise I have is if I use the sunroof. It seems to seat correctly after use but it will squeek a little. I have to open it and clean the rubber seal and painted area of the sunroof cavity.
Old 01-30-2012, 07:48 AM
HEAVY_RL's Avatar
Received 1,041 Likes on 846 Posts
Turn the radio up.
Old 01-30-2012, 07:54 AM
db22's Avatar
Originally Posted by HEAVY_RL
Turn the radio up.
I agree - I told my service writer that it only rattles between songs!
Old 01-30-2012, 09:49 PM
mitchkramez's Avatar
I've have to do the same squeeze routine every couple of weeks too
Old 01-31-2012, 07:30 AM
db22's Avatar
To the mirror!
mitchkramez (02-01-2012)
Old 01-31-2012, 07:32 AM
HEAVY_RL's Avatar
haha, exactly... Owning low end cars most of my life I think I have a higher tolerance for rattles and noise.
Old 01-31-2012, 07:35 AM
HEAVY_RL's Avatar
To the mirror!
haha, I see ya... get out of the gutter DB.
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
dainmezron
10-16-2015 06:56 PM
Quick Reply: Rearview Mirror Buzz
