Rear Sunshade
Rear Sunshade
I have a problem with the rear sunshade, looked around, didn't find much.
when it moves down I see that the screen is not being pulled like it used to be before and sometimes part of the screen stay stuck above causing it next time I'm opening it to get stuck in an angle.
How do I take it apart?
Anyone seen this problem?
Mine does the same thing, but only when it's cold out. In the summer time or after the car heats up, it has no issues. I've decided not to do anything about it because it appears to be temp related.
-ak
-ak
Slightly related, but my sunshade just doesn't work anymore. I never experienced the above problems, it's just that it doesn't go up anymore.
Before it fully stopped working, I would sometimes have to hold down the button before it would go up, so I'm thinking it might be the button itself that malfunctioned.
Anyone experience this before? Also, if I ever do get it fixed, is there a way to prevent it from retracting when I put my car in reverse?
I don't think so, almost every car I've ever driven with a rear sunshade does that. I think the only one I drove that didn't do that was an '06 s430 I drove, but I drove that so long ago that I'm a little fuzzy about that.
Frenetic (12-17-2014)
That's a shame. I really liked the sunshades as I didn't want to tint the windows and I guess that button just wore out, so to speak, from 8 years of constant use.
There's no motor sound when I hit the button, so imagine it's more electronics than anything else.
Could be a fuse, the motor, the switch, or wire harness.
Frenetic (12-18-2014)
Never thought about checking the fuse, but I'm curious, would a bad fuse potentially cause intermittent operation? It always went down in reverse, just the fact that nothing would happen occasionally when I pressed the button for it to go back up prior to stopping altogether?
No. A fuse is binary in nature. The only thing in your scenario I could think of that could cause the fuse to blow would be the motor going out (your intermittent problem) and drawing too much current. Probably unlikely, just throwing out all the paths that need to work for operation.
Frenetic (12-20-2014)
Hey I had the same problem you were having. I finally had some time today to work on the module.
I removed the complete unit from the roof dissembled it into two separate part... the circuit board realized that the sunshade button was not connecting it did not seem worn out.
The fix: I heated up my glue gun and filled the hole half way with a glue pebble…. took it back to the car to test prior to final install and all was ok.
I now have a fully functional sunshade which goes up and down with only one touch…before I had to press 10-15 times and still would not get it up on occasions.
I am just now noticing that the sunshade backlight does not illuminate the button anymore because it’s filled with glue but that’s a small price to pay for a fully functional sunshade now.
Does anyone know if the sunshade button had a light to begin with?
Complete time 45min.
Frenetic (12-21-2014)
Thanks! I suspected it was the button itself as it would always retract upon reverse without pause or issue, but just wouldn't go back up upon pressing that button.
Sounds easy enough, how did you remove the overhead console?
Thanks again.
Thanks again.
Pop off the two plastic map light covers with a flat head screw driver. Remove map light bulbs. There should be some screws in the map light assemblies. Once these are removed, use your fingers to pull the assembly down. Use latex gloves to protect the head liner from the oils on your hands. Once the assembly clips have released, remove the wire harness with a flat head screwdriver by pushing the tab down and out.
Sorry i was away but 007 got you covered. 0007 does your sunshade button have a backlight at nights?
Thanks 007
Thanks 007
Mr.Tea (12-22-2014)
Yes it is...once you open and unscrew the casing you will see the inner piece of the sunshade button which is white...it will align with the (square) hole that needs to be filled.
I have pictures that i can send to you but where and how?
Acurazine now supports picture uploads from your desktop or mobile device. Click the yellow square and chose "Browse".
Mr.Tea (12-23-2014)
It is definitely a button that is losing connectivity somewhere - I just did not bother to open it and fix it.
Choices:
1) Pull down from either side of the upper console (one hand on each side of the console).
2) Palms face forward and pull down from the back of the console (closest to the sunroof).
3) Palms face rearward and pull down from the front of the console (closest to the windshield).
Thanks,
Rob144
My sunshade was acting up again, and with some gumption was able to pull the overhead console down successfully (after removing the lens and the screws).
The console has two round clips towards the front of the car where the console "snaps" into holes in the roof, and there are wide "tabs" towards the rear where the console slots in above the headliner. Since it wasn't fully clear where to pull I started at the rear and sort of pried the headliner away from the tabs, and then kind of went to pulling from the front since that's where the pins are that snap into the roof.
Pitfalls: the pins might stay in the roof, and the plastic on the console where the pins slide in could break. The plastic gets brittle as I learned when putting the dismantled console back together, as the act of tightening the screws caused the plastic mounting holes to detach from the body of the console. My solution was to use a longer screw to carefully tighten the top panel into the lower body of the console into what remained of the hole.
My solution to try to restore the operation of the sunshade button was to thoroughly dismantle the top console. Once it was apart, I found the inner button on the circuit board that gets pushed when you press the outer console sunshade button and opened that up (be very careful as there's a loose metal part inside - which itself is kind of a mini-spring). I cleaned that metal part and the inner contact it touches on the circuit board and reassembled the inner button. I added some aluminum tape to the outside of the inner button to make it a little thicker (so that pressing the outer sunshade button really pushes the inner contact). I reassembled the unit, connected the cable and popped the unit back into place, reinstalled the screws and the lens and tested all the buttons -- so far, so good!
BoricuaTL
04-08-2016 01:08 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
