question about brake fluid and oil viscosity
I got my brake fluid flushed and on the receipt it says dot 4 used. He said it replaced the heavy duty dot 3. Manual says heavy duty dot 3 only and dot 3 or 4 as temporary. Then when I got my brake tsb on brake squeal, its says heavy duty dot 3?? wtf??? Is there someone I can talk to from acura to confirm dot 4 replaced heavy duty dot 3??
And for engine oil, I wanted synthetic but they used 5w30, book says 5w20, is that ok??
Oil should definitely be 5-20.
Get another shop, make sure you get a certified tech and get to know him, if he is really good, only use him. I get unbelievable service. Also, get to know your service advisor, treat him like your best girl friend, it will pay off, always use him, call and ask for him, etc.
Call Acura HQ about the brake fluid.
Synthetic is a waste of money if you do not have a turbo or race. Just chance it often enough, I change mine at 40% left. Cars do over 300-400k miles with regular oil.
Of course, synthetic also handles high temperature's far better than regular oil so if you're in extreme hot temperature's (ie. parts of Arizona, Nevada), synthetic is better.
If you're in the northern part of country where it's below freezing for the winter, I'd say it's worth it. Most engine wear happens at startup and synthetic gives you that low pour point so it will get to the vital parts of the engine faster.
With brake fluid it gets kind of tricky. DOT 3 Fluid is the most generally used fluid in vehicles today. You can mix fluid if the fluid is DOT 3/4 which is compatible with both or DOT 5.1. The dealer may have put in a DOT 3/4 but notated it as a DOT 4.
DOT 3 or DOT 4 is fine. It doesn't need to be Genuine Honda.
5w-20 or 5w-30 is fine. There's little advantage to using 5w-30 in a daily driver but there's definitely no harm in using it.
Synthetic oil is beneficial in very cold climates or if you are racing the vehicle. Simply living in areas with warm temperatures isn't enough to benefit from synthetic oil. Synthetic oil is only useful when oil temperatures rise above 305F, which you'll never reach under daily driving conditions regardless of outside temperature.
mada51589
05-03-2022 08:54 PM
ulrblitzer
09-24-2015 07:42 PM
