Power windows, sunroof, and mirrors no longer working
Has anyone experienced this before. My power windows all switches, sunroof, and power mirrors all quit working yesterday. I have checked the fuses and they seem to be ok. Anyone with any ideas as to what the issue could be? Thanks in advance.
I tried the switch reset in that I held down the down and then the up position for several seconds but no change. I have checked the fuses inside the car and they appear to be fine. There are separate fuses for the left and right windows along with a separate fuse for the sunroof. I did notice a 50a fuse in the box under the hood that indicated it was for the windows but it looks more like a relay and I am not sure how to tell if it is bad. The battery was replaced with an OEM from Acura about a year ago and while I will not totally discount it as being the issue I doubt it.
Did you do the switch reset at each door or at the driver's door? You have to do it at each door.
Do the sunroof and mirrors respond at all? If not, it may be worth trying an electrical reset by disconnecting the battery terminals and holding the cables together for 30 seconds. Of course, make sure you have radio and Nav codes first.
Dealer has told me that the master switch on the drivers door is causing the issue. Part has been ordered and I will know tomorrow if that fixes the problem.
TLDude876
Dec 28, 2016 03:18 PM
sockr1
Oct 1, 2015 01:31 AM
ahsm
Sep 9, 2015 08:35 AM
asahrts
Sep 4, 2015 05:55 PM
