Power Steering
Old Oct 26, 2010 | 05:45 PM
tomb543's Avatar
Question Power Steering
I dont know if im a re-re or what, But for the life of me i can not find out where the power steering fluid goes. i looked everywhere its just escaping my little peanut brain. Could anyone help me out and suggest any particular PS fluid?
Old Oct 26, 2010 | 07:39 PM
Chris Acura's Avatar
I only use Honda power-steering fluid comes in 12oz bottles.
Old Nov 18, 2010 | 06:23 PM
luong47's Avatar
4th Gear
Problem with the power steering warning light
My RL had the smog check yesterday.
After the 2000rpm idle for a couple of minute, the Power Steering warning light lit up.
When I restart , the warning light went off.
but I still have the power steering warning on the message
info.
I then made the 2000 rpr idle when the car is on P and see this waning light came out again after some time. It returne to normal after engine was restarted.
Any one had the same problem ?
Old Nov 19, 2010 | 08:53 AM
Chas2's Avatar
You check your fluid levels?
Have you had the power steering hose recall done? The recall is because fluid leaks out of the system from faulty hose and a *could* be a fire hazard.
Old Dec 2, 2010 | 07:07 PM
luong47's Avatar
4th Gear
power steering warning at 2000rpm idle
I do have recall serviced on pwer steering hose.
This warning dissappear when you restart engine
Seem normal steering after.
I don't know if any one has same problem.
I had it after my first time smog check after 5year .
Every thing seem normal after this warning message.
Thanks for every body feedback
Old Dec 22, 2010 | 03:02 PM
rmjse's Avatar
I have been having an issue where I find my steering wheel harder to turn. When I am driving on a rough road, the steering wheel turns left and right on its own and I find it hard to keep it straight.
Does anyone know if this is a power sterring fluid issue? I have not checked my levels, but I will later on.
Old Dec 25, 2010 | 11:53 AM
rmjse's Avatar
I checked my power steering fluid level and its just below the max line. Yet I still find my steering wheel very stiff and hard to turn. Anyone have any ideas?
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
Euro4gen
Dec 12, 2015 03:14 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
