Personalize the RL
Old Sep 23, 2008 | 12:08 PM
RgalvenizeL's Avatar
Personalize the RL
Hey,
Does anyone know if you can change where it says "Driver 1" (or Driver 2)when you get in the car - I've looked through the manual for a way to change it to my name, but haven't seen if it's possible.
Also, I know we can personalize all the settings using the menu in the instrument cluster, but is there a way to make the display (ie, avg mpg, the SH-AWD display, tire pressure, etc) show the same thing every time you start the car? (i'd like to have the mpg display every time - it currentlty starts blank until i scroll to it)
Also with the personalization, can the RL be set to be playing the same radio station every time you get in the car?
thanks!
Old Sep 23, 2008 | 12:48 PM
getakey's Avatar
I got in trouble making a joke about the name personalization before, so won't go down that path again!
No way to change Driver1 to your name - unless that has changed with 2009, but I doubt it.
Cannot change the MID to default to last setting. It is what it is.
However, your radio setting should lock to last one used for Driver 1 and Driver 2. Similarly, temp settings will save to last one used for each driver.
Old Sep 23, 2008 | 01:25 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
Keep in mind Driver 1 and Driver 2 are also synched to the Fobs which are also named Driver 1 and Driver 2. This allows for personalized settings of the RL.
If you could change the MID display, it could be confusing as to which Fob you should have (1 or 2?). You would always have to remember which name aligned to which Fob Driver #.
Someone must be watching "Night Rider".....
Old Sep 23, 2008 | 07:16 PM
plastikman's Avatar
I don't know what everyones problem was, I found it to be pretty funny.
Old Sep 23, 2008 | 07:33 PM
Ballinger's Avatar
My MID "blanks" when I restart the car. If I tap the "up arrow", it displays what I had it set to before turning the car off. I kinda like that it's off and clean looking, but a simple tap shows my data (I use "instant mpg" ).
Old Sep 30, 2008 | 02:59 AM
PortlandRL's Avatar
I would love to reprogram 'Driver 1' and 'Driver 2' on the MID so you can have the name of the person who usually holds the remote. So it would say "Welcome Robert" or "Welcome [Insert Your Name Here]".
Old Sep 30, 2008 | 06:33 AM
db22's Avatar
If you told the lady in the Nav that driver one was "Robert" then she could ask you,"Good Morning Robert, how may I help you"? It's nice to have the Onstar operator call you by name when you call.
Old Sep 30, 2008 | 06:39 AM
db22's Avatar
If you always used Driver One and your name was Robert then you would only have to remember your own name to eliminate any confusion?
Old Sep 30, 2008 | 07:41 AM
Indeed, this is true for me, as I also am the only driver of my RL.
But from a design standpoint, the RL personal settings are configured to accomodate multiple setting for 2 drivers. From the design standpoint, this could complicate the user experience when 2 drivers are configured and the driver names and Driver # lables must match.
Perhaps an intermediate step could be made in the Driver Setup... Will there be 1 or 2 Drivers? Then name each driver. This is not a stretch as we already voice lable phones in the HFL.
Old Sep 30, 2008 | 08:52 AM
db22's Avatar
So Driver 1 is assigned to Adam and Driver 2 is assigned to Eve. Assuming that Adam and Eve always use their own fob then I don't see a problem. The wench in the nav would check for AM or PM, check the clock for morning or evening, check for Driver 1 or 2 and then recall the correct salutation. This is really simple, it's just that the software writers have never driven a car so they never think of the useful stuff.
Old Sep 30, 2008 | 11:20 AM
I agree db22...it should not be that complicated to apply.
My thinking is that with the Fobs labled Driver 1 and Driver 2 not very clearly, perhaps Honda assumes 2 driver households are too likely to grab the wrong fob and be incorrectly greeted by the car?
But I would like it personalized myself. I would prefer "Welcome Master" or perhaps "Welcome Supreme Being" myself.
On a side note...I am reluctant to update my NAVI DVD as I fear if I am trapped with the female only voice, she will criticize my necktie choice for client meetings.
Old Sep 30, 2008 | 11:25 AM
db22's Avatar
If the present wench works then don't replace her. If she starts to critisize then she should be replaced with a new disc.
08KBP_VA
Oct 22, 2019 01:55 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
lanechanger
Oct 13, 2015 10:56 AM
Sep 21, 2015 08:44 AM
