p0420 p0430 p0171 p0174
As of yesterday all 4 of these codes popped up. My gas mileage is poor and when I reset the light, it comes back in 30ish miles. I placed my assumed fixes based on my findings from the search below, but is there a chance that something else could warrant all these codes? 180k
P0171 & P0174
I must replace the e.g.r valve and all 6 injectors. I may also need the PCM update from the dealer.
P0430 & P0420
The worst case scenario would be two catalytic converters and all 4 o2 sensors.
I did find a post in which an owner stated the first two codes came from a clogged breather hose that came from the transfer case. Is anyone familiar with that?
P0171 & P0174
P0430 & P0420
Have you checked your battery?
Pull off your EGR valve and give it a good cleaning with carb cleaner along with the EGR pipe that goes to the intake manifold.
From what we have seen here, P04#0 codes mean new cats are on the way.
I found someone selling cats from an 08 TL. I recall reading that they fit so I'll have to pick up those.
I don't think those fit if they are from the J32. You need the 3.5L cats from the Accord or TL-S.
Depending on the price, I just might. But then I'll need to fab up defowler
Chans (03-10-2014)
That's where i intended to start. Hopefully a new filter and EGR valve will allow me to hold off on getting the injectors.
A new egr got rid of the p0171 & p0174 codes. The other codes remain so my dreams were killed. My quest for cats continue as the local ones have been sold.
did you replace or lean or both?
SiClone
10-01-2015 10:22 PM
Billu99tl
09-13-2015 11:30 AM
