P0420 check emission system
Old Dec 24, 2021 | 01:25 AM
joshdgr8's Avatar
Hello everyone, i was driving my 2005 Acura RL on the way home and suddenly a P0420 code comes up. i scanned it with my obd2 scanner and it says catalyst system efficiency below threshold. i remember my mechanic once said that he replaced the 2 catalytic converter's in my car 2-3 years ago so it can't be that. Could it be the 2 oxygen sensors that needs to be replaced? i already checked my air intake and everything looks good including the filter. im not sure if i have any leaks but i doubt it.
Old Dec 24, 2021 | 09:24 PM
dzionny_dzionassi's Avatar
It is most likely a CAT. If he replaced with aftermarket unit it is most likely already gone bad.
OEM ceramic cat can last 10years+ but most aftermarket metallic core ones 2-3 years. Unless it is high quality one like Gesi or Vibrant core.
Also damaged CAT must be uninstalled asap, it can damage cylinder bores.
Old Dec 25, 2021 | 02:17 PM
Littleme's Avatar
5th Gear
Somebody correct me if im wrong but it also can be upstream (not downstream)air/fuel (o2)sensor?
Old Dec 26, 2021 | 03:54 PM
joshdgr8's Avatar
my obd2 scanner says bank 1, im not sure whether its sensor 1 or 2
dinodaitalian
1G TSX Problems & Fixes
18
May 15, 2020 09:03 PM
kevinh1919
4G TL Problems & Fixes
Apr 11, 2020 02:31 PM
vtr1000sp2
Sep 4, 2019 07:52 PM
Walfunk
May 25, 2017 03:52 PM
aznxb1az3
Jan 24, 2010 12:10 AM
