P0420 check emission system
Hello everyone, i was driving my 2005 Acura RL on the way home and suddenly a P0420 code comes up. i scanned it with my obd2 scanner and it says catalyst system efficiency below threshold. i remember my mechanic once said that he replaced the 2 catalytic converter's in my car 2-3 years ago so it can't be that. Could it be the 2 oxygen sensors that needs to be replaced? i already checked my air intake and everything looks good including the filter. im not sure if i have any leaks but i doubt it.
It is most likely a CAT. If he replaced with aftermarket unit it is most likely already gone bad.
OEM ceramic cat can last 10years+ but most aftermarket metallic core ones 2-3 years. Unless it is high quality one like Gesi or Vibrant core.
Also damaged CAT must be uninstalled asap, it can damage cylinder bores.
