New RL driver -- Bluetooth Help
Old Oct 1, 2015 | 10:43 PM
Atxrldriver's Avatar
4th Gear
Good evening all!
I am the proud owner of a new-to-me 2006 RL. I wanted to stay under 10k, and this was a great buy!
I am a bit confused by the Bluetooth and was wondering if you might be able to help out.
I understand that I can't stream music from my phone with the factory head unit, but has anyone had any luck using a Bluetooth to 30 pin connector (I have an iPod connection in the glovebox).
Also, I have been using Siri to start phone calls (iPhone 6s +), but haven't figured out how to seemlessly transfer the call to the Bluetooth audio. Sometimes it will pick up automatically, and sometimes I have to change the source to Bluetooth, and then press the dial button to get it over to the car's Bluetooth audio. Is there a good way to do this? I would rather not manually input all my contacts (more than 50) into the phone book.
The car came with no manuals, but I was able to find the owners manual online (not the navigation manual).
Any help would be appreciated.
Thanks!
Old Oct 2, 2015 | 11:05 AM
oo7spy's Avatar
I don't think anyone has tried the Bluetooth to 30 pin unit (I assume you are talking about USASpec BT-45).
If you intiate a call from the phone, you should be able to press the source button and choose BT. What I always did in the RL was use the voice commands to dial the desired number. I only had a few numbers I consistently called, and in pretty good at memorizing numbers though.
Old Oct 2, 2015 | 01:43 PM
4th Gear
I think the USA spec runs through the xm radio in the trunk. It looks like a good option and easy install.
I was thinking more about something like this:
http://www.frys.com/product/7869369?source=google&gclid=CNjx4ri4pMgCFQwwaQodn6 MLVg
Old Oct 2, 2015 | 01:49 PM
oo7spy's Avatar
Oh, the Apple 30 pin connector. I missed the iPod connection in the glovebox part. I suppose that is Acura's not-so-well-known Music Link? Why not buy a lighting to 30-pin adapter?
The USASpec does plug into the XM module in the trunk.
Old Oct 2, 2015 | 04:14 PM
4th Gear
The 30 pin is in the glovebox, and I was really hoping to use Bluetooth to stream audio if there was a solution using the 'music link'
Old Oct 3, 2015 | 02:36 PM
oo7spy's Avatar
Seems like the unit you found should work. As long as the music link doesn't have trouble knowing a unit is there, the signal out of a 30-pin connector is analog, so there is no more decoding to do.
Old Oct 4, 2015 | 07:25 AM
MyAcuraRL's Avatar
From: Indianapolis (Motor Sports Capital of the World)
iPod connector go buy a 30 pin to lightening adapter. As for bluetooth you need to manually input all your contacts. I ended up buying the Usaspec unit for Acura.
FYI: I just found the new USA Spec Bluetooth for Acura RL. USA Spec BT45-ACU
Amazon.com : USA SPEC Acura Bluetooth Interface with XM/ NAV Traffic BT45ACU : Electronics Amazon.com : USA SPEC Acura Bluetooth Interface with XM/ NAV Traffic BT45ACU : Electronics
tman570
Jun 11, 2019 07:56 AM
scionxb3003
Oct 2, 2015 05:50 PM
Krystynoneill
1G RDX (2007-2012)
Sep 15, 2015 09:57 AM
brandnewcolony
Sep 12, 2015 10:39 AM
EE4Life
Sep 11, 2015 10:04 PM
