Nav Update
Does the map accurately cover your area? If it doesn't, has your area been updated with the newer versions?
That's all you get really. My area has expanded drastically since the 2007 disc I had was made, and I felt the $99 specials that run frequently would be worth the update.
I got the nav update offer letter.
Couple of odd things in points of interest counts
Restaurants 2013 505,438 2014 497,270
Department Stores 2013 32,523 2014 31,939
Gas Stations 2013 118,954 2014 114,747
Hotels 2013 78,277 2014 71,073
the total POI counts are shrinking. Only categories that went up were ATMs and Convenient stores
I get that, but the #s don't jive with what has happened in economy. I would expect a lag in the POI data compared to economy. 2010/2011 were bad years, yet # of restaurants in POI data was very high in 2011
OP I'd suggest to do the same, updating every 5 years seem to be a good idea, so if your current disc is more than 5 years old then its time to invest I guess
You can, but it isn't easy. Find the right download, find the right CD type, have the right software, and burn at the slowest speed possible. It will more than likely take you more than one try and a few hours, but it can be done.
I think I have instructions in my PM.
Please do share. I am still in 2005 here lol.
I did it a few years ago and concluded that it was not worth the hassle. I bought 3 Dual layer DVD's but I didn't have a dual layer burner so I had to borrow one. My experimentation quickly used up the 3 so I bought 10 more. Eventually I got it burnt and you then run the possibility of screwing up the car. I did, and had to delve deep to find the secret button pushing to get the car out of a loop. Eventually I got it to work so I burnt another one for a friend and it worked but had issues. Within a year I bought a new one from Navtec and got on with life. If your time is not worth much then go for it but I must have spent about 10 hours total on the project and I now have about 5 DL DVD's sitting in a box because I still do not own a burner to use them.
The ones that I did, don't mess with the firmware at all, I was only successful using Toast Titanium on my Mac, had no dice burning withe the Disk Utility. I found a legitimate upgrade disc on ebay to get my drive to the latest firmware, and all the versions have been fine since.
Can you upgrade the firmware and not the maps? I might buy a legit upgrade disc to see if I can use the downloaded maps. My fear is messing up the firmware. I can just reload the old maps if the downloaded maps are bad.
I have a 2007 RL purchased new. In 2010 I got the advertisement for for a new CD for the nav system. We had a new bridge and several bypasses added in 2008-09 in my local areas, so I thought why not. Well I loaded the disc and guess what...no changes from my 07 disc. My question: is there any way to tell what changes are made before you purchase a new disc?
http://bit.ly/195PW9R
White DVD – 2014 Update
Version 4.C0
Coverage:
US map coverage was expanded to include the following areas:
Highlighted cities are new to the Detailed Coverage Area
Version 4.C0
Coverage:
