Nav hack problem
Old Oct 21, 2010 | 09:26 PM
kssod's Avatar
Nav hack problem
Ok so I bought the 4.92 to upgrade my 08 mdx, and I copied the disk with disk utility to try and use in my06 RL. I was able to do this successfully with the 4.62 that came with the MDX. Installed the disk and software upgraded sucessfuly, but when system restarts get disc error with copy. If I insert oem 4.92 it works fine. Now, i can't go back to 4.62 since the software is more up to date than previous version.
Any idea how to go back to the older Software version
Old Oct 21, 2010 | 09:49 PM
kssod's Avatar
Search and you shall find..... Press map menu and cancel to get to diagnostic screen. Click version, and download . Older version reinstalls from 4.62 disc v 1.64
Old Oct 22, 2010 | 06:04 AM
kssod's Avatar
interesting how a ripped copy can install the updated software ,but then get disc error when system restarts. Software update works because the OEM, 4.92 disc will work. Somehow the OEM is protected just when it goes to access the nav database, not the install. or version update.
Old Oct 29, 2010 | 12:59 AM
Anh85's Avatar
Didn't even know that you could rip and copy the navi disk. I thought it wouldn't read it properly.
Old Oct 29, 2010 | 02:39 AM
Ken1997TL's Avatar
It won't copy properly, something to do with the actual discs themselves rather than the data.
SidhuSaaB
May 30, 2020 12:40 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
