Nav hack problem
Nav hack problem
Ok so I bought the 4.92 to upgrade my 08 mdx, and I copied the disk with disk utility to try and use in my06 RL. I was able to do this successfully with the 4.62 that came with the MDX. Installed the disk and software upgraded sucessfuly, but when system restarts get disc error with copy. If I insert oem 4.92 it works fine. Now, i can't go back to 4.62 since the software is more up to date than previous version.
Any idea how to go back to the older Software version
interesting how a ripped copy can install the updated software ,but then get disc error when system restarts. Software update works because the OEM, 4.92 disc will work. Somehow the OEM is protected just when it goes to access the nav database, not the install. or version update.
Received 2,329 Likes
It won't copy properly, something to do with the actual discs themselves rather than the data.
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
