Mud/splash guard and aspec compatibilty??
Old Aug 3, 2017 | 03:42 PM
deepa1600's Avatar
Hi all, i was wondering if the oem mudguards from base RL would fit an Aspec, since aspec has different body kit. And has anyone used www.parkacuraoemparts.com before??
Old Aug 3, 2017 | 04:08 PM
truonghthe's Avatar
If you have full Aspec lip kit then you won't able to use the mud guard.
Old Aug 3, 2017 | 04:19 PM
deepa1600's Avatar
This is what i have.
Old Aug 3, 2017 | 04:42 PM
truonghthe's Avatar
do you have the rear lip as well? from what I can see you won't able to use the mug guard for the front UNLESS you can do custom trimming on base mud guard (which I never seen one yet).
Old Aug 3, 2017 | 05:10 PM
deepa1600's Avatar
Yes i do. The aspec rims i have are peeling really bad and i will use them for winter tires. Right now i am running Advanti racing 19"X8.5 ET 30. I was thinking of getting mudflap for the front to mask some of the low offset tire bulge. Fortunately i found the mudguards at https://www.parkacuraoemparts.com in black color.
Old Aug 3, 2017 | 06:38 PM
truonghthe's Avatar
Ok you can buy a base mud guard and trim it down (the mud flap made rubber like material), the front one will require alot of work since the Aspec flare out where base sit flat (vertically) the rear one is easier. However I WOULD NOT RECOMMENDED trimming unless you had mad skill. I would leave the car exactly where its now.
This is how its look before mount on a BASE RL.
Old Aug 4, 2017 | 06:30 AM
08KBP_VA's Avatar
Personally I think it looks fine. If all you want to do is mask the offset of tire I think youll end up calling more attention to it.
Jus my .02
Old Aug 5, 2017 | 11:21 PM
Walfunk's Avatar
I think your car looks great as is.
