Moisture in tail light. Desiccant?
I noticed some moisture in one of my tail lights today. Never had an issue until today. There has not been much rain as of late. However, I am washing my car more regularly with the weather finally cooperating. I took the lights out and here's what I found.
The driver's side (the one with the moisture) has 2 holes with something stuffed in it. Looks like sponge. Looks like someone modified it. No other holes where moisture or water can get in as far as I can see.
The passenger's side has black plugs with a rubber ring that seals tight. Inside these plugs is what looks like a small filter. Here's the question.. could that be desiccant? This light has no moisture. I realize that this is also (possibly) some sort of air filter.
I have no idea why someone would remove these plugs. Pics attached. I think in the interim I may stuff some desiccant from my wife's shoe box to see if that helps.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
![Name: IMG_01571_zpsltk1ndph.jpg
Size: 317.1 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/69830d1501422573-moisture-tail-light-desiccant-img_01571_zpsltk1ndph.jpg)
![Name: IMG_01581_zps7dnyjgfm.jpg
Size: 122.8 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/69831d1501422573-moisture-tail-light-desiccant-img_01581_zps7dnyjgfm.jpg)
![Name: IMG_01591_zpszofg3vga.jpg
Size: 173.3 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/69832d1501422573-moisture-tail-light-desiccant-img_01591_zpszofg3vga.jpg)
![Name: IMG_01601_zpssrsvzte1.jpg
Size: 123.3 KB](https://acurazine.com/forums/attachments/2g-rl-2005-2012-76/69833d1501422573-moisture-tail-light-desiccant-img_01601_zpssrsvzte1.jpg)
that would be a vent cap allows the housing to breathe. Light bulbs and LED's create heat so difference in temperature between inside and outside of the housing will create some condensation. i would check the seals on all of your bulbs in the tails to make sure they are in good condition. Or possibly could have put in a bulb wrong not making a complete seal with the housing.
The following 2 users liked this post by Carbon Legend:
Fuchfaccio (05-04-2015),
oo7spy (05-05-2015)
rockyboy
12-06-2022 02:29 PM
guyvelella
09-30-2015 11:02 PM
wusty23jd
09-24-2015 11:41 AM
