might be the end
Old Mar 31, 2014 | 02:24 PM
  #41
getakey's Avatar
awesome. the helicoil will serve its purpose and will hold up.
the other plugs will need to be checked and re-torqed to spec.
also, do you know what cylinder/plug it is?
firewall
456
123
radiator.
if its #2 like I suspect it is.....
hmm - dealer said front center which you have as 2, but they said #5
Old Mar 31, 2014 | 02:28 PM
  #42
either they are confused on the firing order, or I am. at least we agree that its the front center.
i really believe #2 is towards the front. let me make sure.
Old Mar 31, 2014 | 02:31 PM
  #43
HEAVY_RL's Avatar
5 is in the front.
Old Mar 31, 2014 | 02:32 PM
  #44
it was my mistake, #2 cylinder is towards the back and #5 is up front
Old Mar 31, 2014 | 09:18 PM
  #45
oo7spy's Avatar
Everything I read said it was that cylinder too. What makes that one so vulnerable?
Old Mar 31, 2014 | 09:44 PM
  #46
getakey's Avatar
^yeah - what is it about that cylinder?
Old Mar 31, 2014 | 10:19 PM
  #47
cmx168's Avatar
hmm... this is troubling to me... i just replaced my spark plugs and only torqued it to 10 pounds because I read in another thread of warping the head with the factory 13 pounds torque specs. should i go back in and retorque to spec then??
Old Apr 1, 2014 | 07:18 AM
  #48
HEAVY_RL's Avatar
never hurts to check your torque after a few heat cycles.
Old Apr 1, 2014 | 07:54 AM
  #49
aluminum head + pressure = kaboom!?
ripping the threads right out.
All I know is that it happens on most J-series engines. and that it could happen prior to a spark plug change. some have had it happen on stock plugs.
I got scared and checked mine a couple of months ago. ALL were tight.
also, some hear a ticking noise, like air escaping, prior to the ejection.
Old Apr 1, 2014 | 09:33 AM
  #50
oo7spy's Avatar
Heavy, nice avatar, but the designer failed.
Old Apr 1, 2014 | 10:26 AM
  #51
db22's Avatar
Approx 80k miles since service. At 60mph = 1333 hours. Times 60 = 80000 minutes. At 2000 RPM = 160,000,000 pushes against the plug.
It's going to be tough to call the shop on them failing to tighten the plug!
Old Apr 1, 2014 | 02:12 PM
  #52
miner's Avatar
I believe getakey is picking up his RLX Adv today....
Old Apr 1, 2014 | 02:17 PM
  #53
to expound, maybe the firing order has something to do with it.
I remember taking off my intake manifold and seeing a spray pattern on only 2 cylinders. which 2? I've forgotten, but the rest of the cylinders were clean.
same with my buddies car. only 2 cylinders had this spray pattern on it.
weird. and just rambling about my experiences.
Old Apr 1, 2014 | 03:26 PM
  #54
getakey's Avatar
yup- at 2:30
raining crazy today, so probably no pics until it clears up
funny story yesterday while I'm waiting to sign the contract.
Raining yesterday as well and I'm waiting in the lounge. Rain intensifies and I believe it is the Asst Mgr walks by me and says "days like this is why we make AWD". I say - great to tell me that on the day I'm trading my AWD for FWD!
Old Apr 1, 2014 | 03:28 PM
  #55
hahahhaha
congrats on the RLX.
Old Apr 1, 2014 | 04:04 PM
  #56
oo7spy's Avatar
Why a new car over a $700 repair?
It doesn't really matter; . I just didn't see that coming. What did they give you for the RL?
Old Apr 1, 2014 | 04:18 PM
  #57
getakey's Avatar
Its got 183K miles and I did not trust that another plug might go. Have several driving trips planned in near future. Its got other wear and tear issues as well that I'm tired of looking at. Brake job and tires due very soon and up for another A13 service now (10%). If there was a time to unload it I felt now was the time.
Was hoping to hold out until the hybrid, but when I found out the true delta between discounted Advance and Hybrid Advance, I just thought regular one was much better deal.
Old Apr 1, 2014 | 05:56 PM
  #58
getakey's Avatar
Got it and back home
Old Apr 1, 2014 | 06:55 PM
  #59
getakey's Avatar
here's what the plug did on expel
don't ask me why I did not see this when I pulled over and opened the hood.
Old Apr 1, 2014 | 09:19 PM
  #60
oo7spy's Avatar
at the damage.
Fair enough on the reasoning. Enjoy your new car. That is an experience I have only lived vicariously through my wife.
Old Apr 2, 2014 | 08:52 AM
  #61
projektvertx's Avatar
Hot damn!
Old Apr 2, 2014 | 09:04 AM
  #62
no, the other plugs wont go.
and that damage is common. replace the coil pack and hood if damaged
Old Apr 2, 2014 | 12:12 PM
  #63
getakey's Avatar
while searching for the pink slip, I found the sticker from my 2005. MSRP = 48,900.
I remember getting a very good deal on that car too - seems like 41K. Will see if I can find the contract.
In any case, I got the 2014 RLX Advance for 400 more than 2005 list. There was only 1 model in 2005.
Old Apr 2, 2014 | 02:07 PM
  #64
BDoggPrelude's Avatar
Congrats on the new ride, getakey.
Old Apr 2, 2014 | 05:54 PM
  #65
MSW 6SP's Avatar
Old Jul 29, 2014 | 09:19 PM
  #66
beekermartin's Avatar
This is the reason I torqued my plugs down to 25lbs when I installed them last week. I work for a Honda dealer and I have seen this happen on V6's before. I rerightened my wife's Pilot plugs a few months back just to be safe. I also will say that the plugs came out of the RL way to easily. They weren't loose but they broke free with almost no force.
Old Jul 29, 2014 | 09:33 PM
  #67
I should mention that I am not a mechanic. I understand 25lbs might be excessive but I don't beleive that is anywhere near enough pressure to strip the threads. I would rather have it a tad bit tighter than risk the plug loosening up.
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
ceb
ILX
Sep 27, 2015 10:56 AM
Rcelestino93
Sep 23, 2015 10:01 PM
Brandle34
Sep 23, 2015 07:20 PM
