MID Display behavior
Go Big Blue!
As everyone knows, the MID display can toggle through several displays such as SHAWD, TPMS, Trip Computer, etc. However, my RL does not remember the current setting when you turn the car off and restart. It always reverts back to the default "blank" screen. I assumed that was intentional until I picked up my MDX yesterday. The MID on the MDX retains it's last setting and redisplays it the next time you start the car.
How does everyone elses RL MID work? Is my RL broken or did they just get smart with the MDX and realize people would want to have their settings remembered?
Go Big Blue!
Hmmm, this is what I suspected, but, I just wanted to check. To bad they didn't figure out this obvious feature until after they designed the RL in 05
My 06 starts out blank and does not remember where you are, but pressing the up will take you one back to where you were. Say you were on the torque graph, shut down, start up, blank screen, press up button and the torque graph displays, and not something else like the mpg graph, etc.
Mine works exactly as Chas2 describes. Just press the up or down button to go back to where you were, once you restart the car. Sounds like this "feature" was fixed for the MDX.
Go Big Blue!
OK, looks like mine is not broken. Seems they just changed the behavior for the MID when they engineered the MDX. Personally I like how it works with the MDX. I leave mine on the AWD setting. JNot something you need to see to drive the car, but it looks cool
By the way, if we can assume the AWD display is representative of what's really going on with the SHAWD, the MDX works very different then my RL. The MDX is definitely FWD biased while my RL seems more balanced. Even when cruising the MDX shows 3 bars in front and 2 bars in back. The RL is usually very even across all 4 wheels Accelerating the MDX also sends way more power to the front most times (but not always), again, the RL is more balanced. The rear lateral adjustments also seem more pronounced in the MDX. You have to really push the RL to see side-to-side shifts in rear torque. My MDX throws power to the outside wheel even on a "normal" turn.
Torch & Pitchfork Posse
Yep, I agree with that also.
I think we have discussed this before Mikey. The SHAWD of the MDX (and the RX) would have to behave differently between these vehicles and the RL. The yaw sensors, center of gravity etc will respond differently in each of these vehicles and case the SHAWD to react differently.
Without SHAWD the RL is lower and more stable, and requires less 'correction' input by the SHAWD. The taller, dynamically different MDX will input different information into the processor and subsequently the SHAWD will react differently...perhaps as more SHAWD response in a curve where the RL requires little.
I still expect the SHAWD MID was tweaked to look more responsive as I read too frequently it appears the SHAWD in the RL is ineffective. Perhaps a better visual representation of what SHAWD is doing was re-programmed into the MID?
But overall, I would expct the SHAWD to work less in the RL than an MDX, and that would be reflected in the MID display.
Originally Posted by gavine
I still wish the SH-AWD status could be displayed on the NAV screen. How cool would that be?
Somebody, somewhere wrote the code for the operation of the MID. Wouldn't you just like to ask him a few questions?
1 - What were you thinking?
2 - Are you still employed?
3 - This is a joke isn't it?
I don't mind the MID at all....it's just not visible when turning the wheel and that's when you want to see the SH-AWD status (when turning the wheel). If it was on the NAV screen, you would be able to see it batter and so would the passengers.
And when you're turning the wheel and pressing the gas to make the SH-AWD do enough to actually move the bars, your eyes should be ON THE ROAD. Which is why the display is completely stupid, anyway.
Also, Tampa's suggestion of it on a HID would solve that problem and make the display usable.
Go Big Blue!
When you think about it though, the display really has no value. You don't need it to driver better. The system is automatic and you have no influence on what it does. It would be like having a display for the VSA or ABS system. Clearly they added it simply to show off the unique technology, however, I can't imagine them spending additional money to make it more visible. In a way, I'm surprised they spent money to even display it in the first place.
I do think that it makes you a better driver too - I now go much faster around curves while mashing the accelerator, twisting my body under the steering wheel to see a display that has no value. Only RL drivers can do that!
Go Big Blue!
Originally Posted by db22
Just about every review of the RL and the MDX points out the display as a feature that no other car has and that it is entertaining.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
ITSJESTER
17
12-06-2018 02:29 AM
DerrickW
11-15-2015 05:52 PM
joflewbyu2
10-08-2015 11:16 AM
