In the market for a RL
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
What years should I stay away from or what specific years should I look at as far as the 05-08's.
Are there any issues I should look at when looking at one?
lol, stay away from 05s... (I just bought one 2 weeks ago). but here's some things to check for that are common issues:
1. drive shaft/shaft bearing: common failure causes noisy drive train $1500 part + labor
2. torque converter: whirling noise at certain speeds, mainly noticeable at low speeds $900 part + labor
3. AC compressor $900 part plus labor
4. Auto Frontal Light System issues (normally either the AFS ECU or the rear wheel well sensor). The sensor is only $150 os so, but the ECU is nearly $1000
5. Door handles: the smart lock system on them quits working when they get wet $about $250 per handle plus labor or about $400 total installed per side (mine worked fine when I test drove the car, but when I went to pick it up, they washed the car which caused them to temporarily stop working)
6. If you get an 06+, you can wire in a factory back up camera. 05 requires aftermarket install (which is just as easy to install and probably cheaper... but some people prefer OEM). I like my aftermarket backup camera, just like OEM but only $225 for the camera and relay box (navtool).
You can call all the Acura dealers that have serviced the car and ask them what major components have been replaced. But the ones I listed above are the main ones to watch for. In the 2 weeks that I've owned my RL I've had my AC make noise one day (sounded like the compressor), my frontal lighting system gave me an error (but went away), my passenger door touch-lock function quits working whenever the door gets wet and even after a tranny flush, I heard my TC whining one day (hasn't done it since).
These were all things I checked before buying the car that just intermittently popped up (and luckily have gone away). But any of those issues could have been VERY costly.
A. GET A WARRANTY
B. USE OEMACURAPARTS.COM FOR PARTS (WAY CHEAPER THAN MOST DEALERS)
C. USE THE SEARCH FUNCTION HERE, MOST ISSUES ARE FAIRLY COMMON AND HAVE DIYS ON THE FORUM.
I dont regret getting an 05 because I know I can get the parts fairly cheaper from oemacuraparts.com and a lot of the things I can fix myself, or have a local independent shop do for half the price of the dealer. Also, I did pay extra for a 6month/6000 mile warranty through the dealer (I probably should have gone for the 24month/24000 mile but it was more than twice as much as the 6 month one).
A. GET A WARRANTY
A. GET A WARRANTY
A. GET A WARRANTY
I'm wanting to stay in the 20k price range but. If I hold off another year I'll probably look at some 09's then. I'm early in the researching stage.
for about 20k you should be able to find a clean 06. if you buy from a big dealer they can sell you a good warranty (Total Protection Plan is a good one, stay away from C.A.R.S. warranty). my warranty is "pretty close" to the Acura warranty.
Is the backup camera not standard on the RL?
Is there a key in the VIN number to find these models? Sort of like how the MDX's vins you can tell if it's a base, tech, tech w/ ent and etc...?
