malfunction SH-AWD
Old 12-27-2013, 10:14 PM
Rustyboy's Avatar
malfunction SH-AWD
My 08 RL with abt 120K keeps loosing AWD whenever I take a turn at abt 35mph, this usually happens when on and off highway exit. Recently I had my alternator(OEM), aftermarket battery terminal replaced as well as aftermarket battery (interstate). Dealer claims this caused by aftermarket battery terminal. Can this really caused the issue. million thx.
I have AWD code 75 and 77 in the MID.
Old 12-27-2013, 10:24 PM
TonyCD's Avatar
Do you feel your AWD going away in the car's road behavior, or are you just seeing it disappear on the dashboard display?
Old 12-27-2013, 10:30 PM
Rustyboy's Avatar
when the SH-AWD light comes on, I only get front wheel drive.
Old 12-28-2013, 09:08 AM
sOLLEx's Avatar
Check to make sure the fluid is full in both chambers on the rear diff. I would suggest taking it back to another dealer and having them troubleshoot the codes. Replacing the battery with an aftermarket should not have anything to do with these codes.
oo7spy (12-30-2013)
Old 12-28-2013, 07:38 PM
oo7spy's Avatar
Received 7,248 Likes on 4,859 Posts
I'm with sOLLEx. Going around the corner is causing low fluid to "lean" and trip a sensor.
Old 12-28-2013, 09:40 PM
HEAVY_RL's Avatar
Received 1,043 Likes on 848 Posts
I'd replace the fluids for sure. I think someone else had a sensor fail causing the same codes.
As for the terminal, it all depends. Usually a bad battery kills an alternator.
Old 12-29-2013, 12:05 PM
Rustyboy's Avatar
quote by dealer:
121921 had code 75-1 acc device, 78-1 shawd unit failure 77-1 something in trans, coded 1.00 all of these codes did not come back, had new interstate battery, and aftermarket cable end on positive side of battery, weak battery could cause all these codes, if they come back i would start with cable.
Old 12-29-2013, 04:12 PM
sOLLEx's Avatar
Is that what the tech wrote? An aftermarket battery cable is not going to cause just your SH-AWD to go into limp mode while going through turns. After they cleared the codes, how long was it until the codes came back? Was it while driving? If these were just history codes, they would not be disabling the AWD. Like I said previously, check your fluid level/condition. If it is good, then you will have to troubleshoot the codes that keep returning. Could be a faulty shift solenoid valve in the diff, SH-AWD control unit, or even the rear diff itself.
The following 2 users liked this post by sOLLEx:
HEAVY_RL (12-30-2013), oo7spy (12-30-2013)
Old 12-31-2013, 01:19 AM
Rustyboy's Avatar
The error msg came back within 30min I picked up from them. I'll take check it tmr.
thanks! keeping my fingers crossed.
Old 12-31-2013, 08:17 AM
EL19's Avatar
I'm with everyone else to check fluid levels in the diff
joflewbyu2
08-18-2019 10:38 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
AJRozsa
10-05-2015 07:50 PM
c1souk
09-28-2015 11:20 AM
saturno_v
09-27-2015 08:13 AM
Quick Reply: malfunction SH-AWD
