AT make loud crack/ bang/noise when going into reverse
AT make loud cracking noise when going into reverse
I changed the ATF on my 2005 RL... now the vehicle has a loud crack when I shift to reverse. Vehicle also seem like it is in neutral when the gas pedal is pushed. The Green D flashes when the vehicle is put in reverse. The vehicle then refuses to go into gear to drive or reverse.
broken axles is your best case scenario
![](https://cimg4.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1124/img_1547_e05d54598e42b6cabfcbe3e95f5ce4d5cbce3b53.png)
I changed it approximately 8,000 ago... come to think of it, the reason I changed it was because of hesitant acceleration... I did a 3x3 and it started driving and accelerating very smoothly. The veh has approximately 190,000 miles on it. It was running like a dream.
This time I checked the ATF and it was low. I drained it all out because it appeared dark and I put in 3 quarts.... It now has the loud cracking noise in reverse and sometime the transmission would not engage.
