Loose drivers side mirror
Old Mar 4, 2008 | 05:27 PM
andrewmr's Avatar
I've read here that there a few of you that have had problems with the mirror (door) coming loose. Does anyone know how to tighten it back up? Does the door panel need to come off or does it get tightened from the outside?
Old Mar 4, 2008 | 11:43 PM
supergreen's Avatar
Interesting! The driver side mirror on my car was loose when I bought it (used.)
I always assumed the previous owner hit it with something (even though there were no visible scratches or dings.)
Either way, the dealership replaced it at no charge... maybe because they have seen the problem before??
Old Mar 5, 2008 | 06:52 AM
fafpak's Avatar
Andrewmr,
See the thread at https://acurazine.com/forums/showthread.php?t=4074
Lot of info there. I just went through the ordeal of trying to tighten them myself.
Good luck.
Old Mar 6, 2008 | 07:48 AM
static808's Avatar
I got my driver side mirror replaced and noticed when I was closing the passenger door that the passenger mirror was very loose. Going to the dealer to see if they can tighten it.
Old Apr 8, 2008 | 08:17 AM
123456SPEED's Avatar
CLS 6MT Navi
I test drove an 06 and the driver mirror was vibrating. The whole housing was loose. I guess this defect is kinda common.
Old Apr 8, 2008 | 11:35 PM
elton's Avatar
8th Gear
my freinds rl the mirrors where loose i looked under them theres this access panel poped it off theres i think a few screws tighten them up and no more loose mirrors
Old Apr 12, 2008 | 12:20 PM
gcook's Avatar
I noticed that my driver's side mirror appears to be coming apart at the seam on top. Has anyone seen this? There is a 1/2 mm gap where the plastic meets.. right on top of the mirror.
Old Apr 12, 2008 | 11:35 PM
sleepinxlionhart's Avatar
My driver's side is sort of loose too. It was like that when I bought it new from the dealer..
hey elton, how did you pop off the panel under the mirror? Because I see a little hole/access point, but it's so close to the body of the car that I really don't have a tool that can work for it.
Old Apr 19, 2008 | 10:07 PM
jfprl's Avatar
I used an L shaped craftsman pick. Inserted in the hole and pulled the cover off.
Old Jan 28, 2009 | 05:07 PM
LARAIDER's Avatar
3rd Gear
This thread was very helpful, I fashioned my tool from a 6 inch piece of a hanger and bent the last 1/4 inch to an L shape, it worked great.
rockyboy
Aug 4, 2024 10:35 AM
marcelft
Jul 10, 2018 06:17 PM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
