Looking for CMBS error solution.
Old Jan 3, 2014 | 01:46 PM
gman44116's Avatar
Need More HP!!!
CMBS/ACC Error 30 popped up 4 days ago.
Battery tested at 12.64 V.
Did a battery reset.
Rechecked battery connections.
Cleaned off the grill and front logo.
Keyless locks stopped as well.
Any other suggestions? Could it still be the battery?
Old Jan 3, 2014 | 02:22 PM
HEAVY_RL's Avatar
yes
Old Jan 3, 2014 | 08:22 PM
gman44116's Avatar
Need More HP!!!
Any thoughts on not paying dealer for diagnostics? Acura battery was replaced by dealer (prior owner) back in 2010.
Old Jan 3, 2014 | 10:20 PM
oo7spy's Avatar
I could still be your battery. 4 years is well beyond average for this car. One way or another, you are going to have to buy a battery in the next year or so. I would use take the opportunity now and avoid potentially unnecessary diagnostics ($100 anyway) and debug.
Old Jan 3, 2014 | 10:31 PM
gman44116's Avatar
Need More HP!!!
If the battery is still pushing 12.64V, if my understanding is correct its functioning fine. Can the CCA be low if the volts are still at 100%?
The second battery is under warranty if I'm correct.
Old Jan 4, 2014 | 07:37 AM
oo7spy's Avatar
Resting voltage means nothing, really. A more prudent test would be with the ignition in position II without the car on. Even then, many RLs pass dealer and auto shop battery tests under load and still have battery issues.
I have a feeling you will have a hard time claiming warranty. Acura will play dumb and demand a receipt and will likely say it can't be transferred if you do produce one. Or, they will claim the battery is fine and charge you to diagnose false issues. It's worth a try, but don't be surprised if they deny the claim like they have to so many others here.
Old Jan 28, 2014 | 11:53 AM
gman44116's Avatar
Need More HP!!!
Update.
Thought it was the battery. Still had 60% coverage on replacement battery so had battery replaced. Cranking on old was 317. Almost cooked. But, that wasn't the issue.
There's a $15 part called the brake switch assembly. The old one was loose.
If this switch malfunctions, cruise control is deactivated. The culprit for CMBS warning lights.
The stealership wanted $140 haha. It's a 5 minute time frame to replace. DIY.
Old Jan 28, 2014 | 12:51 PM
oo7spy's Avatar
Old Mar 13, 2014 | 09:34 PM
tla11384's Avatar
I have the same problem with the CMBS light on (code 30). Where and how did you change the brake switch assembly?
Old Mar 13, 2014 | 10:39 PM
oo7spy's Avatar
If it is the same one that fucks with the CHMSL, it is on the brake pedal bracket.
blacktsxwagon
Oct 27, 2015 10:12 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
