Lights flickering on 2005 RL
I purchase my RL a month ago and now everytime I turn the headlights on, my driverside headlight flicker then go out. If I turn the lights off and back on it comes on again for a lil while then goes right back out. Do I need a new blub, or should I changed both blubs, My car have 150,000 miles on it,
Could be bulb or ballast from the many, many threads we have seen here on the exact same topic.
I would start with bulbs first since they likely haven't been replaced in 9 years. Change both if you want the same color.
That's what im thinking, I will try to replace the blubs first to see if that work's, if not then I will need to replace the ballast. I just want to know should I get a used one or a aftermarket ballast kit. cause the dealer wants 300 bucks just for the ballast.
I don't see $300 on here anywhere. Call them back and ask what part number they plan to use.
http://stores.revolutionparts.com/oe...peed-automatic
Theretrofitsource.com does carry our Matsushita ballast. you can give them a call and see if they can sell you one. Great company to work with awesome customer service.
edit here is the link to the ballast
http://www.theretrofitsource.com/com...l#.Uzy_zPldV8E
Occasionally it would flicker on the driver side as well until the same flickering bulb turned pink; I replaced both of the bulbs from Amazon - got some Phillips HID bulbs for I think around $100 and it cost me 90$ at the shop to swap them... no issues after that at all... balast wise, this was not the issue in my case.
Ol'Dave
Sep 5, 2020 02:56 PM
handsom-hustla
Nov 13, 2015 05:04 PM
