Light out in seat heater switch
The bulb which illuminates the seat heater switch keeps going on and off. If it is off, I tap it and it goes on. Have any of you guys replaced this bulb? Tough job?
I am out of warranty.
Does the seat heater stay on when the bulb isn't lit? May be a bigger issue.
If it's the bulb, it looks like an easy fix (once you get the switch out). Part number 35601-SJA-A01 or 35602-SJA-A01 depending on which bulb you need (uses one of the first and two of the second). Each lists for $8.38. You can get the entire switch as well. Part no. 35600-SJA-A01 (right) or 35650-SJA-A01 (left). $55.87 list.
LL
LL
I have same problem with mine, my driver's side seat heater light is out. Along with my ac adjustment switch.
I had the same problem with both the climate blue/red driver side and seat heater driver side. got them both replaced but the climate one is out again. Seems like a problem for our cars!
donnie
My seat heater lights went out twice so far. The dealer replaced them under warrenty. My temp switch for the ac unti went out too. there is no way to change the lights without replacing the whole entire ac/audio face unit. Luckily it went out before my warrenty expired it would have been very expensive.
LL
LL
Thanks in advance.
I plan on doing it myself. You should consider getting a subscription to Alldata.com. There you can find instructions on replacing the switch. Once you have the switch out you peel back the tape, unscrew the light and screw in the new light.
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
