LED Running lights
#41
Throw a resistor between the two wires. $2 and done.
#43
Just one side, driver's or passenger will work. A diagram would only add confusion to an already simple process. Find the back of the bulb. There are two wires going to it. Attach a resistor between the two wires. Just jeep in mind the power equation.
Also, keep in mind the alternator may put out 14+ volts, so use P = 225/R for the power rating.
#44
#46
I meant the wires coming from the harness of the car that is normally plugged into the highbeam bulb.
#47
I like that look. What did you have to do to get the original DRLs to stay off, and the fogs turn on without the low beams? I looked through the various links posted in this thread but didn't see anything, and search is broken right now for some reason.
#50
Correct. As long as one side sees a load (resistor, bulb, anything that draws current) the DRL code will not appear.
#51
Flagship Aspec
Thanks, I had some leds from the previous car so I threw them in but now I have the code. I found some plug-n-plays that come in pairs and wasn't sure if I needed to order 2 sets or just the one. I recently got an rdx as well and wanted to do the same
#53
The error eliminators don't work?
How about a resistor?
#55
Hey guys! I have read that some people mention LED lights for RLs. Were there cars with Halogen lights and LEDs? What do I have on my 2010 RL with Tech package (has Nav but doesn't have collision mitigation stuff)?
mada51589
05-03-2022 08:54 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
