Keyless Entry / Immobilizer Disabled
#81
I think the fact that a flat bladed screwdriver did not turn while pushed in (the lights came on and steering column moved) means that there is no fob in the car. That's exactly what happens when you try to turn the knob cover with no fob in the car.
His goal now is to find if and where that immobilizer chip from the key is hidden at.
#82
was hoping to hear an update on this
#86
as said earlier : you definetely don't have a fob in your car.
here's the size of the chip you are looking for :
the lowest part in the center of this picture.
some remote starter installs i've seen : installer sticked the chip in the column covers, really close to the ignition switch
it has to be very close, not a foot farther.
In your pictures, the bright green connector is the harness that transmits immo information from chip to ECU.
it could've been taped with a harness : look for a bump or electrical tape applied differently than OEM (OEM tape is applied very consistently from harness manufacturers)
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
