Keyless Entry / Immobilizer Disabled
Old Oct 21, 2012 | 04:54 PM
  #81
Megatron's Avatar
Originally Posted by oo7spy
I wonder if you could get just the outside of the ignition needed for the plastic cover to work?
I would check catalog if I had my computer.
Yes, that's available as an individual part for less than $10. The problem is... if the fob is not in the car, and he doesn't have a programmed fob to use, then with that original plastic piece in the cylinder, his Ilco key will no longer fit all the way in and so he wouldn't be able to use the key until he took the piece back out again.
I think the fact that a flat bladed screwdriver did not turn while pushed in (the lights came on and steering column moved) means that there is no fob in the car. That's exactly what happens when you try to turn the knob cover with no fob in the car.
His goal now is to find if and where that immobilizer chip from the key is hidden at.
Old Nov 1, 2012 | 01:36 PM
  #82
getakey's Avatar
was hoping to hear an update on this
Old Nov 1, 2012 | 05:48 PM
  #83
HEAVY_RL's Avatar
yea what a let down
Old Nov 2, 2012 | 12:56 PM
  #84
mdlesk's Avatar
Still trying to locate the transponder chip. I'm only home 1 day a week and haven't had time to look further yet
Old Nov 2, 2012 | 06:37 PM
  #85
HEAVY_RL's Avatar
Old Nov 2, 2012 | 11:56 PM
  #86
Type S Zero's Avatar
as said earlier : you definetely don't have a fob in your car.
here's the size of the chip you are looking for :
the lowest part in the center of this picture.
some remote starter installs i've seen : installer sticked the chip in the column covers, really close to the ignition switch
it has to be very close, not a foot farther.
In your pictures, the bright green connector is the harness that transmits immo information from chip to ECU.
it could've been taped with a harness : look for a bump or electrical tape applied differently than OEM (OEM tape is applied very consistently from harness manufacturers)
MrHeeltoe
20
Feb 23, 2023 01:54 PM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
