How do I remove the door panel?
Old Mar 10, 2016 | 05:36 AM
scottsan's Avatar
I took off two screws from the door panel and I can pull it ALMOST off, but it's sticking in the middle area. There are two wires / cables that are connecting the door panel to the door.
Any way to remove this easily?
Here's a pic from the top.
Thank you for any advice.
Old Mar 10, 2016 | 10:07 AM
titomang's Avatar
Here's a link that will help out. Next time please run a search.
https://acurazine.com/forums/second-...irrors-911689/
There's two clips in the middle towards the top that will need to be popped out. I believe this may be your problem.
Old Mar 10, 2016 | 10:11 AM
oo7spy's Avatar
Just above your map pocket is an LED panel that pops out to expose a screw behind it if I remember correctly.
Old Mar 10, 2016 | 02:47 PM
scottsan's Avatar
That is an awesome DIY! Thank you so much!
scottsan's Avatar
and thank you too as usual
Old Mar 10, 2016 | 05:17 PM
scottsan's Avatar
Thanks again guys. Just replaced my speaker and can't be happier! Felt like an mechanic.
Old Mar 10, 2016 | 06:11 PM
titomang's Avatar
Glad you were able to get that panel off. Did you replace it with a factory speaker or aftermarket? If so, what kind?
Old Mar 11, 2016 | 12:20 AM
scottsan's Avatar
Just factory Bose
My previous one blew out. I don't listen to music loud, I don't know how it did that.
Old Mar 11, 2016 | 10:15 AM
oo7spy's Avatar
Because Bose is crap.
bell2
3G MDX (2014-2020)
71
Nov 16, 2020 07:24 PM
ShekiShabazz
Jan 26, 2016 01:04 AM
hopslover
1G CL Problems & Fixes
Jan 21, 2016 10:59 PM
mazen222
Jan 11, 2016 05:57 PM
