How do I make the "Check Keyless Access System" message go away?
Old Oct 23, 2016 | 01:02 AM
scottsan's Avatar
So my proximity sensor doesn't work and I'm willing to let the feature go...
I would like to just get the orange "Check Keyless Access System" message to go away. Is there a way to do this?
I am comfortable removing the handle, fuse, etc.
Old Oct 27, 2016 | 11:24 AM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
https://acurazine.com/forums/second-...system-871397/
Old Oct 27, 2016 | 12:03 PM
RL09's Avatar
https://acurazine.com/forums/2g-rl-a...-issue-877951/
Old Oct 27, 2016 | 01:38 PM
NathanJax's Avatar
So since this thread was already started, I figured I'd piggy back on it with my "Check Keyless Entry System" issue that started this morning. Every handle work, starting the car works, but the trunk no longer seams to work with the proximity sensor. The latch is fine. The FOB button works fine, I can pop it from the door button. So it seems just the proximity sensor went bad overnight.....
Anyone ever have this issue?
Old Nov 24, 2021 | 05:09 PM
iaamaafg's Avatar
3rd Gear
Keyless Access issue
I have the same issue. It might have started because the battery died on my car. ?? Any idea how to fix this issue? is this a fuse issue?
Old Jan 3, 2024 | 10:04 PM
Alvarez7120's Avatar
Check keyless access system
Hey did you ever figure out what this problem was? My car is giving me that message also even though my key fob works to lock and unlock the doors.
lowther420
ILX Audio, Bluetooth, Electronics & Navigation
Nov 7, 2016 03:31 PM
