How do I disable DRL?
Old Jun 3, 2009 | 01:20 PM
  #41
CFoote's Avatar
Cutting the white wire will not get rid of the error message. It will kill the DRLs, but the computer is smarter
What you need to do is find out where the relay for the DRLs are. Obviously that white wire (2v) is feeding a relay which turns the DRLs on. Ground out that relay and you are set.
I haven't had time to research this but if someone can find the relay that the white wire feeds I think we'd be in good shape.
Chris
Old Jun 3, 2009 | 03:41 PM
  #42
037's Avatar
037
or you take out the DRL bulbs and tie them in a place you can't see.
Old Jun 4, 2009 | 07:27 AM
  #43
fredren's Avatar
unofficial HONDA rep
am then you lose your highbeam..what we are trying to accomplish here is to turn off the drl while still utilizing the highbeam function.
Old Jun 4, 2009 | 11:10 AM
  #44
037's Avatar
037
in that case you do what I did.
Install HID.
They DO NOT work as DRL, you will get a nice error.
High beams kick @$$
so, how do you not get an error? DRIVE WITH LOW BEAMS ON!
brilliant...
I've mentioned this like 100 posts ago.
Old Jun 5, 2009 | 09:30 PM
  #45
woodek's Avatar
Anyone tried putting a switch in the circuit instead of a total disable? Seems pretty easy......
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
joflewbyu2
Oct 8, 2015 11:16 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
