HID bulb change
Old 03-13-2011, 09:10 PM
Carbon Legend's Avatar
HID bulb change
Ive been looking around for this info i downloaded the service manuals for the RL and i must be blind because i cannot see it anywhere in the service manual.
Do you have to do the wheel well trick or do you have to remove the headlamp assembly?
Old 03-13-2011, 09:25 PM
white05rl's Avatar
Neither, here's a link that should help:
https://acurazine.com/forums/showt...ight=white05rl
Are you replacing both? If not, which one?
Old 03-13-2011, 09:27 PM
white05rl's Avatar
https://acurazine.com/forums/showthr...ight=white05rl
Old 03-13-2011, 09:32 PM
im actually going to do some 55W Ballast that i have laying around and going to upgrade the bulbs to some Phillips DL50 bulbs and possibly playing around with the spacing to get a sharper cutoff possibly increase the color/flicker of the light
Old 03-13-2011, 10:12 PM
037's Avatar
you don't need to remove the bumper to swap out the bulbs. When my headlights were going offI just swapped out 2 bulbs, w/ the hood open in under 30 minutes (I've done it more than once before) and the lights stopped going off.
as far as 50w conversion, I've tried it with not so good results.
If you want to get it done right, get good ballasts and good bulbs, use a separate harness for each ballast as one harness is not strong enough for two.
good luck!
Old 03-13-2011, 10:16 PM
im no stranger when it comes to HID conversions. I will be using Modified Hella Gen3 ballast with a switch to adjust the output from 35-45-55W. Not these cheap aftermarkets ballast like DDM (Not knocking them just not my taste i know several people using them with success)
The Phillips DL50 bulbs are meant to handle the 50W load from the ballast and they are not cheap bulbs at all. not to mention the quality of a phillips HID product is always top notch
Old 03-13-2011, 11:35 PM
037's Avatar
I'd love to see part numbers and details of what you're doing. I've been meaning to go 50w on my low beams forever. Are you making AFS work too?
oo7spy
06-19-2023 12:48 AM
BoricuaTL
04-08-2016 01:08 PM
Silverstead1
09-17-2015 06:45 AM
Aleax
09-11-2015 11:31 AM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
Quick Reply: HID bulb change
