HELP! Ignition Is locked
Old 01-22-2017, 05:53 PM
Shoxrider's Avatar
So my 2005 wouldn't unlock with the fob, had to use the key, I've been trying to jump it- charging it for about for 15 min,and the ignition is like locked. I've tried to move the steering wheel and the shifter. The ignition will not turn into 1 or 2 even with the key placed inside it..: any suggestions?
Old 01-22-2017, 05:54 PM
Shoxrider's Avatar
Seats won't move and no lights come on
Old 01-22-2017, 06:02 PM
Received 8,692 Likes on 6,706 Posts
Check your battery....
Old 01-22-2017, 06:03 PM
Shoxrider's Avatar
Battery has been charging for 15 min
And the ignition is locked
Old 01-22-2017, 06:06 PM
what kind of charger are you using?
and just to confirm, you've undone the terminals to the car prior to charging right?
Old 01-22-2017, 06:07 PM
Shoxrider's Avatar
Using our other car while it's running, terminals still connected on RL
Old 01-22-2017, 06:10 PM
How to Charge a Dead Car Battery (with Pictures) - wikiHow
I think you need a new battery.
Old 01-22-2017, 09:24 PM
Paul1204's Avatar
Your steering wheel is locked. Turn it a lil hard to the right and turn the ignition
its a safety lock i guess to keep it from being stolen. Alot of hondas and acuras have this
Old 01-22-2017, 09:46 PM
Shoxrider's Avatar
It's not a steering wheel lock and it's not the battery
I replaced the battery and it is having the same symptoms. The lights on the front doors do not turn on when you open the doors but the overheads work and the rear door lights and leds... all the fuses are intact. My last RL the door handle shorted out the entire car but the door handle fuses are intact. Just had the car towed to the dealer.....
Old 01-23-2017, 12:28 PM
Shoxrider's Avatar
Update
It was my door handles that shorted out the car. For some reason it didn't blow the fuse 🤔
projektvertx (01-23-2017)
Old 01-23-2017, 12:48 PM
mgmny's Avatar
You've had two RLs both of which had a door handle immobilize your car???
Old 01-23-2017, 12:50 PM
Shoxrider's Avatar
Yes! 😫
second time now. Last time the appropriate fuse was blowing... not this time
Old 01-23-2017, 01:51 PM
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
This is not an uncommon failure mode.
projektvertx (01-24-2017)
