Help I have a problem with my honda legend 08 (acura rl )
Hi guys, my name is Alfonso and I from Spanish. I writing this e-mail because i have a problem with my honda legend and nobody knows what's wrong. The battery discharge in 3 or 4 days. If I disconnect the fuse number 7 (10a) don`t discharge the battery. I disconnect front left door module, the alarm, the bt module, front seats. The car haven´t key less access. Can someone help me?
I´m sorry for my English. I´m learning.
Thanks.
Thanks.
Your english is fine.
Start by reading these links, they may help you:
https://acurazine.com/forums/second-...7-fuse-971754/
https://acurazine.com/forums/third-g...-drain-900441/
Fk no!TheyldstroyEvrthing
Thanks.
Thanks.
If you disconnected left door handle, and it still does it, then reconnect it, and disconnect the right door handle. Handles are number one problem.
But, battery discharge so quick, is it while car is parked, or driven daily? Coz that's too fast. How old is the battery?
Good luck.
HEAVY_RL (11-14-2019)
Also, when you say "bt module", does it meanyou have HFL (hands free link)? If so, do you remember it getting stuck while on? Or did you leave the car while you were talking, and continue the conversation after just turning the car off?
That, will get you in trouble. Everyone should either hang up, or switch from bluetooth to normal phone operation BEFORE turning off the car.
Disconnecting the power entirely, and reconnecting may also help reset anything stuck and draining power.
Reset: https://acurazine.com/forums/2g-rl-a...-reset-847010/
Honda calls it the 'Hands Free Telehone' over here.
I replaced mine (it died) with an Acura unit. It will need re-setting by a Honda dealer, though. My car now only understands an American accent...
Does the Acura Link have a Spanish language option? I've not bothered to find out...
when I turn off my car the HFL don´t disconected, but I disconected the HFL module and the battery draw a some days.
Hi everybody.
My car don´t has key easy or hands free key , I distrust the panel instrument, display panel or cd player unit. My car in this moment has a AGM battery. I remplace it this week but this isn´t the solution, I want to fix my car because it´s a excelent car.
bye.
bye.
Hi guys.how I be into of my house and I get bored I repar the problem my car and I`ve obserbed that the electric seats and electric steering column with swich off and without keys always Works , even if going hours. Is that correct?. When you turn off the swich and pass 20 or 30 minutes they shouldn`t have tourn off?
Hola
Los asientos y la columna de dirección permanecen activos; puede quitar las alfombrillas para limpiarlas.
Presione el botón 1 o 2 con la ignición encendida para regresarlos a donde estaban.
chrisrc
02-03-2015 02:42 AM
ONTHEMOVE
09-18-2014 01:38 PM
