Gas Cap problems in RL
Old Mar 2, 2008 | 03:17 AM
NJRonbo's Avatar
A week ago we had a really bad freeze in our area and when I went
out to gas up my RL, the attendant had an impossible time getting
the cap back on.
So, I left the gas cap loose in the locked door for a few days, that is,
until a warning light came on about a gas cap problem.
So, I unlocked the gas door and since it was warmer, I was able to
screw the gas cap back on tightly (a couple clicks).
Problem is, the dashboard info. center is still flashing me warning
messages about my gas cap. Can't get rid of the message, and I'm
wondering why it's still warning me of a problem.
Any suggestions?
Old Mar 2, 2008 | 04:57 AM
robarsan's Avatar
It may take a number of engine re-starts for the warning light to go out. The system has to verify that the pressure loss has been corrected. Some cars (Audi) will not reset automatically; I'm not sure about Acura.
Old Mar 2, 2008 | 06:25 AM
lland's Avatar
Similar thing happend to our MDX. Even after making sure the cap was screwed on securely (very hard to turn), the warning light would not go off. Turned out to be a bad gas cap. A little plastic tab was bent so even though it was on tight, it wasn't making a good seal. Dealer replaced it under warranty.
LL
EDIT: Just checked my RL. It doesn't have the same plastic tabs on the gas cap that the RL does but if the light stays on, I'd have the gas cap checked out anyway.
Old Mar 2, 2008 | 07:27 AM
NJRonbo's Avatar
Thanks guys. I will have it checked out.
Old Mar 2, 2008 | 11:08 AM
Chas2's Avatar
There is another thread that went through all of this about a year or more ago. In that thread, I posted the text from the Owner's Manual that addressed this problem. The car has to be driven a certain amount of time and distance over a certain speed, in order for it to verify that the fuel vapor emissions system is not leaking (an open or loose cap means the system is leaking fumes into the atmosphere, which of course is an emissions issue).
This does not have to be dealer reset as the other message implies must happen with the Audi.
Old Mar 2, 2008 | 11:16 AM
NJRonbo's Avatar
I appreciate you reposting this. I'm happy to learn that I will not
have to make a trip to my dealer and that over a period of normal
driving the problem will just take care of itself. Thank you!
Old Mar 2, 2008 | 02:16 PM
vluu's Avatar
the cap back on.
Any suggestions?
I was going to start a thread on this. I just had the same problem on my 2006 RL and I had the car for 15 months and this is the first time it happened. I tried to tighten the gas cap on 2 times when filling up and after 2 weeks on, it was driving me "NUTS". I was going in for a B service soon, so figured that I would have them check it out then. Well, I just got gas last Friday and after turning the gas cap 3 times in a complete cycle. When I started the engine...it was "GONE". Not sure if the cap is a defect or something, but when I do go in to the dealership, I might ask them to double check again...since I'm still under warranty.
Hope yours goes away... it's very annoying b/c it kept coming up to check on the NAV screen and would freeze sometimes...and take like 5 minutes to go away. Stranges thing?
Old Mar 3, 2008 | 11:09 AM
NJRonbo's Avatar
As predicted in this thread, it was just a matter of time until the
gas cap warning light went out. It did so this morning.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
sockr1
Oct 1, 2015 01:31 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
