front and rear diff
Old May 31, 2014 | 11:28 PM
thanklessjob's Avatar
front and rear diff
what's the difference btwn the front and rear differential on a 2005 RL?
Are they both part of the rear differential( with a front and rear chamber)?
What's the cost to change each one at the dealer?
How often should it be changed? every 15,000-30,000 miles?
thanks in advance
Old Jun 1, 2014 | 09:41 AM
oo7spy's Avatar
There is only one diff at the rear axle, and it has 2 chambers. IIRC, the front chamber takes just over a qt and the rear takes just over 2. The manual will tell you how much and how often.
Old Jun 1, 2014 | 12:29 PM
so at the dealership, is it
front differential fluid change -$90
rear differential fluid change-$90
total=$180
or is it
rear differential fluid-$90(for front and rear chambers)?
Old Jun 1, 2014 | 12:59 PM
oo7spy's Avatar
I can't quote a dealer, but the diff service entails both chambers. It is only one charge. Just make sure they refill both chambers, or you will end up with a new diff like Heavy did.
With an oil pump and a way to get the car off the ground, it's an easy DIY.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
yesSIR-S
May 13, 2016 05:42 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
Sep 4, 2015 08:03 AM
