fog light question..
Old Feb 8, 2015 | 08:41 PM
FoxRL's Avatar
I have searched and didn't find my answer.
Question: Does the 2006 Acura RL share the same fog light with another Acura vehicle?
Ie: rsx, tsx, tl
Obviously different brackets...
Old Feb 8, 2015 | 10:38 PM
oo7spy's Avatar
Why don't you compare the results from here: Lamp Replacement Guide Home
Old Feb 9, 2015 | 07:12 AM
FoxRL's Avatar
Mind you I checked that site on my cell phone but it is only showing me the bulbs.
I was inquiring on the actual fog light itself as 1 of mine is cracked.
Old Feb 9, 2015 | 09:00 AM
oo7spy's Avatar
Oh, fog light assembly... I gotcha now.
Should I give you the link to Oemacuraparts.com?
Old Feb 9, 2015 | 09:10 AM
projektvertx's Avatar
^I would do as doggyman 007spy suggested Compare part #'s is probably your best option
Old Feb 9, 2015 | 09:15 AM
oo7spy's Avatar
They have pictures too...
Old Feb 9, 2015 | 10:35 AM
titomang's Avatar
I'm not certain, but I think the 07-08 TL fogs are interchangeable. My buddy has an 08 type s and the shape looks identical.
Old Feb 9, 2015 | 11:01 AM
FoxRL's Avatar
I did look at the oemacuraparts site - which i thank them for putting pictures on - I printed some off and colored them too
06 RL: 33901-SJA-A01
07 TL: 33901-SEP-A01
06 TSX: 33901-SEC-A01
The difference is the middle section letter sequence. So I guess that answers my question. It seems the mounting hardware on some are a permanent fixture?
It seems like there are no used/aftermarket foglights for this car on the internet.
Let the search continue....
Thanks for the help and sarcasm
Old Feb 9, 2015 | 12:18 PM
titomang's Avatar
Theretrofitsource is coming out w/ LED foglights with full housing that supposedly fits the 2G RL. I would wait for it to see what they have to offer if you're not in a rush. $160 plus 15% discount isn't too bad.
Old Feb 9, 2015 | 12:29 PM
oo7spy's Avatar
There have been a few retrofits of Ford Fusion Fog lights into the RL, but I can't recall any other models.
Old Feb 10, 2015 | 09:29 AM
FoxRL's Avatar
From what I have seen on google - it looks like you need the alternative front bumper/lip in order to make it work/look nice. (Liek the mugen bumper)
Old Feb 10, 2015 | 11:42 AM
oo7spy's Avatar
That's probably true.
Old Feb 10, 2015 | 11:53 AM
I honestly don't see my fusion retro working without the ASPEC lip, it would just look odd, but if you mount it further recessed into the foglight slot, it could work. I mounted it in such a way to fit with the aspec black cutout.
EDIT: One of the biggest issues is shrouds with my setup, you WILL NOT find a shroud that's drop in. Any shroud requires some serious modification because I attempt to mount the from the inside of the bumper if that makes sense. You make have better luck mounting something on the outside with a stock bumper.
Old Feb 10, 2015 | 12:07 PM
FoxRL's Avatar
" I mounted it in such a way to fit with the aspec black cutout"
soooooooooooooooo......do you have the old oem fog lights kicking around by chance lol.
Old Feb 10, 2015 | 12:10 PM
Those are long gone Sorry!
Old Feb 10, 2015 | 03:22 PM
citidelx's Avatar
RoadRunner
The lights are exactly the same on those model years.
Old Feb 11, 2015 | 08:14 AM
FoxRL's Avatar
Citidelx - Are you saying that I can buy a fog light from one of those models and take off its mounting hardware and add the RL mounting hardware?
I does look like you can remove the mounting hardware (judging by the photo of the member that did the glass replacement diy)
Old Feb 11, 2015 | 08:35 AM
Yup, the bracket can be separated from the housing. I don't know much about the interchangeability of the part though.
Old Feb 11, 2015 | 08:51 AM
FoxRL's Avatar
Maybe I'll buy one from a TL and try it out. IMO, it would be dumb of Honda (and probably more expensive) to change the whole fog light casing for different models (ie - different hole alignment, etc).
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
